51
This discussion topic has been answered Discussion topic: Humming noise that disappears when using PCM
This message was authored by: Zero_Saran
Re: The puck is making weird noises and high pitched with Dolby digital audio active
Just got mine today. Pick is quiet until change source on tv then get high pitch noise through the speakers of tv.
Even happens when on the menu/ homepage. So hoping more a setting before splashing out in cable?
 Any suggestions on what setting to change to test it out ?
This message was authored by: Siggy69
I had the same issue, turns out it was my tv settings, I had sound mode set to movies, once I turned sound mode off, the high pitch whine stopped.
So annoying, but that whine was driving me crazy, my tinnitus is bad enough.
This message was authored by: Fremento
Puk noise
I'm a new Sky user and have sky stream with puk. The puk is making a whirring noise which is significantly noticeable when I turn the tv volume down. The puk is also slow to respond to the remote. Could it be faulty?
Re: Puk noise
@Fremento  As there are no moving parts in the puck it's not possible for it to make such a sound.
Are you sure it's a Stream puck?
Re: Puk noise
Yes definitely stream puk. Other family who already have sky have also noticed the noise and commented. We all think it's the puk.
Re: Puk noise
@Fremento  As advised there are no moving parts in it, no fan, no hard drive.
It's impossible for it to be making any whirring sound.
Does this sound stop if you remove the power cable? If not the it's another device doing this.
Re: Puk noise
Report the issue to Sky and request a replacement Puck😉
Re: Puk noise
We have had similar on here with Puk making odd noises.
It is usually related to the speakers that the Puk is connected to, whether that is TV speakers or a soundbar.
Try changing the audio settings to another audio option and see if it resolves it.
you can do that in the Puk settings here;
Settings>Picture and sound>Sound
Select Digital audio output HDMI and change to another sound option there.
This message was authored by: Skull+Treaty
Re: Puk noise
There is an older thread and some users have managed to stop the noise, as you mentioned @lettice  by changing some audio related settings - here
Re: Puk noise
Thank you @Skull+Treaty it's seems to have worked 👍
This message was authored by: Mister_Dalek
Re: Puk noise
You should still get the puck replaced. A Stream puck should be silent.
Any internally produced noise is a symptom of poor manufacture. The pucks are mass-produced and build quality can vary. Get Sky to replace it.
This message was authored by: DantheSwan
Re: Puk noise
@GD1 Why are you telling this person false information?
A simple forum search will show many many people have had this exact situation happen to them including myself
It IS possible for the puck to make such a noise, mine did it , so did about 20 others who've posted on these very forums
My fix was to buy a newer HD lead as I pay for UHD and Atmos so changing a setting to PCM was not an option
These forums should enable users to flag false information from other users!
Re: Puk noise
@DantheSwan  The puck can make a buzzing/humming noise as per the other thread, but not a whirring nouse as whirring suggests a moving part such as fan or hard drive so the info posted is valid.
If the poster said buzzing or humming sound then yes the puck can make these noises.    There is a big diffeence in noises and the types of noise.
PS there is  areport post optuion on every post if you feel info is incorrect use the function to report a post.
Re: Humming noise
@Tom_-22  thatis an unusual fault and it is hard to even work out how a puck could produce a noise that changes when you change audio ouput as the units are entirely digital. However I would call Sky to get the unit swapped.
Avatar for Tom_-22
This message was authored by: Tom_-22
Re: Humming noise
Thank you for your message. I will give them a call.
Answered - Go to Answer
