3
This discussion topic has been answered Discussion topic: Mic won’t work on remote controller, sky stream
This message was authored by: Jack997
I have tried repairing the remote, removing batteries and turning the box off nothing seems to be working. My remote works in the bedroom puck just not the lounge puck! Very frustrating as every shortcut is voice controlled
This message was authored by: Jporch316 Answer
Re: Mic won’t work on remote controller, sky stream
Also try this
The remote can be reset and paired again following these steps;
  1.   Press and hold 7 and 9 together on your Sky remote for three seconds.
  2.   Press and hold 4 and 6 together for three seconds.
  3.   Press and hold 1 and 3 together for three seconds and follow the on-screen instructions.
Replace remote under warranty
https://www.sky.com/help/forms/streaming-tv-remote
Have you pulled the plug completely from the wall ? Worth a try
Avatar for Jack997
I'll try that, from what I read it said not to but that's the old school reset way so why not.
thanks
Also try this
