50
This discussion topic has been answered Discussion topic: Humming noise that disappears when using PCM
This message was authored by: KevNewMedia
Re: Humming noise that disappears when using PCM
Posted by a Sky employee
Hi Everyone
We've been investigating the problem in the background, and I'm wondering if this issue remains for people?
Can you let me know please?
Kev
Community Manager
This message was authored by: Gijimes333
Yes I still have this and it's actually worse than ever. Using lg tv with Sonos sound bar.
Thanks for coming back to me @Gijimes333
I'm going to send you a private message.
Kev
Community Manager
This message was authored by: DaveNW
Hi
Ive just signed up, and getting the issue when selecting any other audio setting than PCM. I'm using a Hisense U7N tv using the built in speakers as it has Dolby Atmos built in. There's another thread here https://helpforum.sky.com/t5/Sky-Stream/Sky-stream-making-a-buzzing-noise/m-p/4915490/highlight/fals... where someone else has reported it. I've referred them to this thread.
This message was authored by: Veii
Yes, I get this whenever sound isn't being output by the Stream box and I'm not on the PCM setting. It means I can't use any setting other than PCM, but then again with the Lip Sync Issue and the fact that Dolby Atmos won't play properly for me I'm on PCM anyway....
Toshiba 65" Fire TV
Sounds like someone flat lining in hospital. A continuous tone.
Just using the TV's inbuilt speakers.
This message was authored by: Ros6
Re: My sky stream puck makes a constant buzzing/humming noise when audio is on.
I also have the humming sound. TV is a TCL through a TCL soundbar. It's an issue with the sky stream box, PCM fixes it slightly but it's an inferior sound to Dolby digital so I don't consider it a fix. I also have a voice syncing issues which no amount of messing with can fix. Very frustrating.
Answered - Go to Answer
