This discussion topic has been answered Discussion topic: defetive handset
Message posted on 06 Mar 2026 11:07 AM
I have a Sky multi room box unfortunately the handset buttons have become difficult to operate and are intermitent in use. Where can I get a new replacement handset?
Message posted on 06 Mar 2026 11:14 AM
@Neighbourjim
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken or faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
In the meantime if you have an android or Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
@Neighbourjim
Message posted on 06 Mar 2026 11:19 AM
Re: defetive handset
Thanks for response, have tried several stores unable to find correct handset. Bought two online both defective. I thought I could purchase from Sky but this doesnt appear a possibility. Cheers
Message posted on 07 Mar 2026 08:12 AM - last edited: 07 Mar 2026 08:13 AM
Did you pair the ones you bought online with the box?
I seriously doubt they were both defective.
You can't buy them from Sky because they will replace faulty ones for free as they're loaned to you with the box.
Message posted on 07 Mar 2026 11:53 AM
Many thanks for input. Bought two handsets online, (not boxed, maybe 2nd hand) paired them to multi-room box, both handests had buttons which were difficult to press/operate and non responsive.
Where or How do I get new handsets? I have three multi-room boxes, several years old and all handsets suffering normal wear and tear.
Grateful for any help or advice.
Message posted on 07 Mar 2026 12:27 PM
Use the link in my earlier post, but I doubt Sky will send you three. Remotes for Sky Q can be purchased in most larger supermarkets, Argos, Asda Living etc.
Message posted on 08 Mar 2026 09:13 AM - last edited: 08 Mar 2026 09:17 AM
My remotes are all 10 years old
This is the "normal wear & tear" on the one just here in this room 😉
I imagine you'll get all 3 replaced if you go through the troubleshooter process 3 times. Maybe not all at the same time though.
