Discussion topic: Sky Q slow download speed using BT
This message was authored by: Lincsdefender
BT Broadband working working perfectly and at high speed however Sky movie downloading at 1%  every 3 mins!
clearly a problem Skys end , rebooting service is not an easy option due to other services.
ongoing problem
Re: Sky Q slow download speed using BT
Hi @Lincsdefender   What exactly are you trying to download, title and format?
Avatar for Lincsdefender
Hi just a film of sky cinema, which took 30mins to reach the point where it could be watched .
Netflix buffers most evening s
In the past sky engineers have installed a Sky booster in order to make Sky Q think it's on Sky broadband .
Modem hard wired to main Sky box and wi fi to  Q .
Hi @Lincsdefender   One example, Mission Impossible - The Final UHD HDR 2h 44m. Gigaclear 600 broadband, ready to watch in 15 seconds, fully downloaded in 18 minutes 45 seconds (23.1GB). If you would like me to test a specific example (title & format) to see if it is a problem at Sky's end, please let me know.
Have you got wifi disabled on the Q?
This message was authored by: Me134
What does this mean? Are you saying that the main Q box is hardwired via ethernet cable and it's a mini box you're trying to use? (Obviously the mini box can't store anything on itself as everything is stored on the main box)
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Not to my knowledge 🤔 the main sky box is hard wired whereas the sky q mini ( other room) is dependent on wi fi .
Turn off 2.4GHz wifi. The mini connection ises 5GHz
the box will randomly use wifi even with a configured ethernet connection.
or even let the mini handle the internet connection
