25
Discussion topic: Virtual Remote Control
This message was authored by Pogit This message was authored by: Pogit
I'm not sure if I've just woken up from a dream or I'm still dreaming.
I don't often use sky go but that might just about to change, finally something I've been asking for a long time has been answered!   Hurray!
on Sky+ I used to use the apps virtual remote to control my main and other boxes around the home a great mobility tool!  On Sky Q I was always told it was coming (many years now!) but it finally has.
under settings > devices you can select sky remote!
and boom there's a remote on my phone for my sky box.
I now no longer have to use that horrid third part app with adverts all over it!
WELL DONE SKY!  Please let other customers who've been asking for this know and please make it an option from the main screen.
oh yeah and please add REMINDERS with auto tune now and I might just be tempted not to cancel at end of contract.  I was 100% going to now it's 50/50 that's how much this means again well done!
SkyQ 2TBv3 (32B206 - Q270.000.10.9L (5u193ht) (Ethernet) on LGUM7400, SkyQMini (32D0B2 - Q270.000.10.9L (5u193ht) (Ethernet) Virgin Media BB.
This message was authored by Chloe-W22 This message was authored by: Chloe-W22 Answer
Re: Virtual Remote Control
Posted by a Sky employee
Thanks for the post @Pogit, the product teams have been working hard at this one so appreciate your feedback on it!
The latest Sky Go release is gradually rolling out with the last of the user base set to receive it a week today 🎊
And as mentioned by @cookiemonsteruk this will be on Android later on but we don't have a time frame just yet.
Chloe-W22
Community Manager
Have a story you want to share with us? Send your Thanks to Sky here
This message was authored by PandJ2020 This message was authored by: PandJ2020
Neat, just tried it - handy if the remote fails...
I am just another Sky customer and my views are my own
@Pogit
@PandJ2020
Are you using iphones?
What version of sky go are you on?
@cookiemonsteruk wrote:
@Pogit
@PandJ2020
iPad v23.5.1. (I guess same on iPhone)
@PandJ2020
Android 13 v 23.5.1
Guess they are rolling out on everything apple first
This message was authored by rscott This message was authored by: rscott
It is due to arrive on Android as well, but not sure when.
Pogit
@cookiemonsteruk Sorry yes should of mentioned it's iOS SkyGO version 23.5 brings the ability to change the Home Screen it would of been nice if adding the virtual remote was an option but perhaps they wanted to introduce it slowly under the radar, whoops 😬
Still shocked its finally turned up tbh after so long of being told it's coming, then no it's not happening.
I needs to come out from the depths of settings though.
@Pogit
Thanks. Had to go to superuser forum for community management to clarify. It was mentioned in april for IOS users and you have been the first customer i have seen reporting it 👍 Android users get it later on
This message was authored by best+of+the+best This message was authored by: best+of+the+best
Android always last to get it again nothings changed then always Apple first
July 19th 2011 ios Iphone and Ipad
February 20th 2012 Android
July 10th 2023 Iphone Ipad
Most likely February 2024 for Android won't be getting an iPhone either 🤣🤣
Pogit
I usually find it the other way around.
Chloe-W22
Community Manager
This message was authored by simon194 This message was authored by: simon194
The problem is the number of versions of Android and making it compatible with all of them although I'm not sure it is necessary to still support Android 5.1 like the current Sky Go app does. Any versions earlier than Android 10 are no longer recieving security updates now.
_____________________________________________________
This message was authored by tiashannon This message was authored by: tiashannon
I've gone into settings and devices and don't have the remote option.  What am I doing wrong?
What device are you using?
iPhone 12 mini
