Discussion topic: UHD on a mini box
This message was authored by: Batbatbatbatbat
UHD on a mini box
Hello. Chased sky twice and despite them saying they would flick the switch I can't access UHD on the mini box as I can on my main box. Any ideas?
Re: UHD on a mini box
hi @Batbatbatbatbat
Not sure who you have been discussing this with but SKY Minis have never been able to support UHD
Edit :Also, unfortunately SKY Q cannot downscale UHD recordings to play on a Mini even in HD
There's no switch to flick.
The mini's do not support UHD.  (It's a hardware limitation)
Avatar for Batbatbatbatbat
Many thanks. Several customer service reps is the answer! Appalling.
so there is no way to get uhd on a second box?
Not with Sky Q.
Only via Glass/Stream but it's quite a different product (no recording).
@Batbatbatbatbat
Worth remembering that Q is approaching its eighth birthday (released early 2016) and was designed at a time when having even one UHD television set was much less common.  As indicated, Sky Stream is the product intended for UHD output in multiple rooms, bandwidth permitting.
This message was authored by: seti-yeti
It's a pity Sky doesn't encourage you to swap to streaming. There are DVRs to preserve the record feature so why not offer one on streaming? Or, how about making the switch financially tempting?
I'll tell you why not: recordings can skip through ads and streams can force ads to play.
