Discussion topic: Remote reset not working
Message posted on ‎08 Oct 2023 10:11 PM
My sky q remote stopped working with my mini box. I've tried holding 7 and 9 together, and then holding 1 and 3, but when I do the 1 and 3, it says please wait for a while then says 'setup unsuccessful'. I've done this about 20 times now and it's unsuccessful every time!
I'm not sure what else to try. The buttons on the remote are now controlling the sky box, but I can't use my remote before to control volume and turn on/off TV.
Any help as to what to what else I can try would be great. Thanks!
Message posted on ‎08 Oct 2023 10:24 PM
Re: Remote reset not working
Hi @Helsbels
After you have reset the remote to infrared (pressing and holding 7 & 9 until the remote led flashes 4 times) then you must make sure that you are pointing the remote at the mini box Infrared sensor when you press and hold 1 & 3
Message posted on ‎09 Oct 2023 09:40 AM
That is exactly what I was trying. And every time it said it setup was unsuccessful.
Message posted on ‎09 Oct 2023 10:02 AM
Hi @Helsbels
Try a Reset Settings in the mini box hidden menu.
After the Reset you will have to re pair your mini Bluetooth remote.
If you cannot switch the mini box on with the remote after the Reset press the Standby button (Amber led) on the front of the box.
Make sure that you are pointing the remote at the mini box when you press 1 & 3 together.
Message posted on ‎11 Apr 2025 01:53 PM
Help me sat my sky mini QBox
