This discussion topic has been answered Discussion topic: Sky Q mini box uhd not compatible
Message posted on 27 Nov 2024 01:47 PM
Purchased new uhd tv only to find out sky Q mini box is not compatible with uhd
Message posted on 27 Nov 2024 03:13 PM
@SteveS2 wrote:Thanks I realise that but then you have to sign in to each app again pain!
Sure, but only once...
Message posted on 27 Nov 2024 01:58 PM
Re: Sky Q mini box uhd not compatible
Sorry that you did not realise this..
It is not really a secret and anyone visiting these groups will find we try to point this out regularly.
SKY mini boxes have not changed since their introduction when UHD was really in it's infancy & the hardware just doesn;t support it
If you really want to get SKY in UHD on your new TV you would need consider switching to SKY Stream but it is a different product and relies on good internet connection
Message posted on 27 Nov 2024 02:00 PM
Thanks I now have good broadband connection having had to switch from sky to get fibre broadband
Message posted on 27 Nov 2024 02:05 PM - last edited: 27 Nov 2024 02:07 PM
As noted, the mini cannot output UHD. (Nor, annoyingly, downscale material to play in HD)
However, depending on the material you want to watch you may be able to use the TV's in-built apps for UHD, e.g. NetFlix.
Message posted on 27 Nov 2024 02:53 PM
