This discussion topic has been answered Discussion topic: No UHD on mini box
Message posted on 30 Sep 2023 01:16 PM
There should be a downscale to HD on the mini box to save all the hassle of having to record 2 programs just so that I can watch UHD on the main box and HD on the mini box. Surely Sky can get a workaround to this. Anyone else have a workaround ? Just recorded some F1 UHD and can't watch while I recuperate from an operation in my bed.
Message posted on 30 Sep 2023 01:18 PM
There isn't a workaround. UHD coverage/ recording is not available on mini boxes nor is that likely to change in the future.
Message posted on 30 Sep 2023 01:19 PM
Re: No UHD on mini box
Sorry @mwbruce the only workaround is, as you have suggested, record both UHD & HD, if you want to be able to watch in UHD on the main box or mini box to catch up.
Message posted on 30 Sep 2023 04:52 PM
Taking UHD down to HD, particularly in anything like real time, without introducing unwanted image artifacts is a non-trivial computing task and way beyond the silicon found in Q (or any other 'set-top box') : even a reasonably powerful PC would have a significant render duration for that job.
