64
This discussion topic has been answered Discussion topic: Sky tv loses Internet connection
Re: Sky tv loses Internet connection
@JudeT wrote:
We are having the same issue. Ever since we changed internet provider away from sky the sky q boxes keep disconnecting from the internet and as others have said every other device in the house is connected and working fine. Where can I find a phone number to actually talk to a human? Sky do not make it easy to phone them!
@JudeT I know you said you turned everything off but did you reset the router by poressing the small button on the back of it
This message was authored by: Cregoe
I'm having the same issue.  We have Virgin Broadband and there's no issue with, as all other devices remain connected and wifi checker remains around 200Mbs.
Generally, I just need to Reset on Sky Q Settings and it sorts itself out, but very frustrating..!!
Sky Q box is only a few months old...
This message was authored by: Seanyd2
Same here. New sky q box but still happening. Thinking of cancelling my contract cos I'm paying for stuff I can't use
This message was authored by: Krigby14
I've tried switching it off and resetting but that has not solved the issue
what else can I try? Is there a number I can ring?
This message was authored by: JudeT
So after going through the process of getting go fibre back out (and there were issues there and router replaced) the issue was not resolved. Long story short ended up with sky engineer out and we have 2 sky routers and a go fibre router all connected. It took him ages to sort it out and figure out what to do but it was never going to be something we'd have figured out ourselves. So far so good though everything has stayed connected!
This message was authored by: Paula_smy69
My sky Q box won't connect to the internet, even though I have hard wired it to the sky router. I have turned everything off and when reconnecting it, I have pressed and held the wps button and the message said it could not find the internet.
We have already tried that
This message was authored by: MustangMark
Hello.
Having similar issues but discovered something quite strange.
I recently bought a Samsung soundbar and connected it to my SkyQ box and Samsung TV via eARC.
What I’ve noticed is that as soon as the soundbar is connected to the system the internet connection is dropped on the SkyQ box. It won't connect via WiFi or via network cable !
If I remove the soundbar and try again, the internet works fine on the Sky box.
Any ideas?
Very odd!
Hello.
Any ideas?
Very odd!
Also forgot to mention that the SkyQ box was changed but the problem still exists!
This message was authored by: sparcs
Having the same issue since Apr 2024.
I have a superb internet and wifi and know  its not my internet at fault, logs prove that .  I work in IT and have no issues with networks.
This is a SKY issue and has worked for years up until this period .
Reading the posts above  it seems to me something has changed at their end  since April.
SKY box says  its connected to internet , and all Apps fails say its not connected to internet .
- a few times I have turned things off and reset but this is rubbish .
This message was authored by: SoOli
Have done what is suggested but can not see wps button. I am going around in circles here
This message was authored by: Stu123c
@portlygoldie  try putting your firewall down one setting on your hub
@sparcs @SoOli try changing your firewall down one setting on your hub (not off tho)
This message was authored by: atherlon
Mines doing exactly the same since last update , how do I change the firewall settings in router ?
Answered - Go to Answer
