Discussion topic: Sky Q not connecting through Gigaclear
This message was authored by Nick79 This message was authored by: Nick79
Sky Q box connects to Gogaclear router but not to Internet despite Gigaclear providing Internet access to every othe device in the house.  Worked fine for last 5 years but failing now.  There seems to be an incompatibility between Shy Q box and Gigaclear ...
This message was authored by MightyQuinn This message was authored by: MightyQuinn
Re: Sky Q not connecting through Gigaclear
Hi @Nick79   In these situations it is best the power reboot everything. Switch everything off and then then plug everything back in in sequence, moving on the next device once the preious one is fully up. Order: Modem, Router, Sky Q Main box.  Do you have the lastest Linksys router MX5500?
Nick79
Thanks.  I have done the power downand re-booting.  Not sure what type of router I have do you think it could be a router fault or an incompatibility due to an out of date / old router ?
Hi @Nick79
Assume you cannot connect your Q box by Ethernet.
If not try a Network Reset found in Q box Home - Settings - Setup - Network.
As you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Nick79
Thanks.  I have tried conecting by Ethernet / Wired and by various WiFi routes with the same result.  Connecting to the router is OK but it cannot connect on to the Internet.  I have done multiplle re-sets, re-boots with total power down for the box and rebooted the router muliple times.....
Hi @Nick79
When Q boxes are connected by Ethernet you can then switch off all Q box WiFi.
(provided you have no mini boxes on WiFi)
On the main Q box first carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router.    Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
Provided you have no mini boxes on WiFi as soon as it connects go into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
Nick79
Thanks.  Tried switching off Sky WiFi.  Main box and mini boxes all connected by wire.  Mini boxes are showing a fault but I hope that fixing the main box will also fix any and all issues with mini boxes.  I have also tried abanding all wired connections and doing everthing through WiFi a=with same result....
Hi @Nick79
If your Ethernet cables are viable (fully correctly wired) you should have no issues with full Ethernet connection.  Thats assuming all boxes are connected by the same method to the same Network.   It's no good just switching off the WiFi and it's best to use the following procedure.
When all boxes are connected by Ethernet you can then switch off all Q box WiFi.
Start with main Q box and first carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router (or Sky router if on Sky Broadband). Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
As soon as it connects go into the Q box hidden menu and turn off WiFi.
Repeat the network reset on any minis in the Mini Home menu with the Ethernet connected. Again do not do any WPS and just wait for it to connect.
Once it is connected go into the mini hidden menu (same procedure as above) and turn off both bands of WiFi. Confirm before exit.
Nick79
Thanks again.  I believe the Ethernet cables are working and fully wired.  They worked fine for 5 years and I have swopped them around and used cables that work  - ie enable other devices to connect to the Internet.  I am also able to connect to the router (but not the Internet) through WiFi and get the same error.  I believe the problem lies in the software compatibilty between router and the Sky Q software - either there is a fault with the router  or some kind of firewall on Gigaclear's side preventing Internet access ??
This message was authored by becklesmp This message was authored by: becklesmp
Hi
We're also seeing the same issue with the sky mini box and not wanting to connect to a 3rd party (Gigaclear) provider.
We have the MX5500 router and additional mesh node which connects perfectly to other devices in the house, however the Sky Q Mini box keeps on dropping the connection.
So far I've tried network resets, restarts, and moved the mini box next to the router for the initial network setup.
When I returned the mini box to the bedroom, the connection worked for 2mins and then promptly dropped out again.
Any additional suggestions would be more than welcome.
This message was authored by Gonker63 This message was authored by: Gonker63
is this still an active post? We have the same issue & would like to discuss it further!
This message was authored by Chodley This message was authored by: Chodley
Try changing your DNS on the sky box to 1.1.1.1 or 8.8.8.8
