Discussion topic: Sky Q new customer box
Message posted on 22 Aug 2023 10:06 PM
Hi all , just ordered Sky Q from sky + , what box shall I expect to get ? What's the standard issue box that everyone will get ? Thank you
Message posted on 22 Aug 2023 07:55 PM
Hdmi input on sky Q box
Hi all , I'm getting a 1tb hd sky Q box soon , I've seen pics online of sky Q boxes and noticed some have a HDMI input on the back , do they still have this ?
Message posted on 22 Aug 2023 08:15 PM
Re: Hdmi input on sky Q box
No they have not been on any of the later boxes.
Also I think that those that did have them did not actually use them and were listed as 'for future use'
Message posted on 22 Aug 2023 08:24 PM
Thank you
Message posted on 22 Aug 2023 10:09 PM
Re: Sky Q new customer box
You should have been told on the call
you will at least get a 1tb basic box
however you may have been given a 2tb uhd box
allowing that double storage and uhd
Sky q is great for everything really no matter what box you get
youll find it a lot better than sky+ @edgie700
Message posted on 22 Aug 2023 10:10 PM
Hi @edgie700
Normally the 1TB UHD is the standard box now.
However some people have taken a low cost deal to upgrade and have the 1 TB non UHD box.
Message posted on 22 Aug 2023 10:14 PM
Thank you for your replies , the agent told me I was getting a 1tb non uhd box because I hadn't took out a uhd subscription, I'm not bothered about 4k as I'm happy with HD , I just didn't want him giving me the cheaper box when the normal thing to do is get the 1tb uhd box
Message posted on 22 Aug 2023 10:16 PM
no aslong as your not bothered about 4k the 1tb box is perfect
like i said
bit of a difference from sky+
Thanks , I hope it's a bit more " modern " than the ageing sky + lol
Message posted on 22 Aug 2023 10:40 PM
Sky Q lnb
Hi all , currently have sky+hd , just ordered Sky Q HD ( not 4k ) do I need a new LNB ?? The agent hasn't mentioned anything about this , he just ordered a box and said it's easy to install for myself.....
Message posted on 23 Aug 2023 12:04 AM
Re: Sky Q lnb
My LNB was replaced when I did the upgrade from the same box. Installer told me it had to be replaced to upgrade to the Q boxes.
Message posted on 23 Aug 2023 12:21 AM - last edited: 23 Aug 2023 12:21 AM
Re: Sky Q lnb
Yes. You can't use a SkyHD LNB with Sky Q.
Message posted on 23 Aug 2023 05:46 AM
Re: Sky Q lnb
You will need an engineer visit to swap from Sky+HD to Sky Q. It's not a simple self-install.
Message posted on 23 Aug 2023 07:32 AM
@edgie700 As long as you don't use Reminders, Bookmarks, Slow Motion or any of the other features from Sky+HD that aren't in Sky Q.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 23 Aug 2023 07:34 AM
Re: Sky Q lnb
Thanks everyone for your replies , I currently have the EL025 LNB , I'll have to ring sky again to ask them to change it
