Discussion topic: Sky Q new customer box
Avatar for edgie700
Level 4 icon
This message was authored by: edgie700
Re: Sky Q lnb
@Daniel0210 he said the box is easy to install, plug it in and follow the instructions on screen
Avatar for edgie700
Level 4 icon
Re: Sky Q new customer box
Hi , I never knew sky + had slow motion , could never see the point of reminders after it stopped automatically changing the channel over to the channel I had a reminder set for , it just flashed up " reminder " and I had to manually change the channel
@spencerdalby1 wrote:
no aslong as your not bothered about 4k the 1tb box is perfect
like i said
bit of a difference from sky+
@edgie700
Further to @oldfella 's note however you should also note that the non UHD box only supports 1 active mini and can record less programmes at once (3 I think vs 6)
Needless to say if you ever want a UHd box there is likely to be a charge
Re: Sky Q lnb
@edgie700 wrote:
Thanks everyone for your replies , I currently have the EL025 LNB , I'll have to ring sky again to ask them to change it
No need. The installer will check and replace as necessary as part of the process.
Re: Sky Q lnb
hi @edgie700
As some of your posts have cast doubt on whether they have booked an engineer to visit to swap the LNB and install (as they normally do)  - they probably have but there does seem to be some doubt,  I have escalated your post to SKY who, hopefully, will be in touch to go over what has been booked and cover off anything else regarding the switch
Please see this link re the escalation and what you might see:
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
If you are using Safari I believe you must make sure that 'Hide IP adress' is not checked in settings to be able to see it - if you have difficulty finding that setting then may be try accessing here with another browser
Avatar for edgie700
Level 4 icon
Hi , thanks , I've actually just checked the my sky app and there's a notification in there saying I need to contact them regarding an engineer visit
Have you checked your MySky track order, it should reference an enginner visit with date.
https://www.sky.com/ordertracking
Sky do not taht I have heard send out a Sky Q main box for self install for a new Sky Q customer or a customer upgrading from Sky+
As an aside @edgie700
Although I know you have ordered your upgrade I still think it may be worth reading some general notes I have put together for people considering moving from SKY HD to SKY Q.
Although it is fairly long and some of it may not be releveant to you I do suggest you read in case there is something you may find useful (especially the note about being unable to revert back)
SKY HD to SKY Q
This message was authored by: Greenfingers001
Re: Sky Q lnb
Posted by a Sky employee
Thanks for escalating this. We’ve sent @edgie700 an invite to chat.
Re: Sky Q lnb
Suspect he might have been new!!
Avatar for edgie700
Level 4 icon
Tbh I've never  had 4k so I'm not that bothered about it , the guy on the phone tried to take £99 off me for the basic 1tb non uhd box, then he said he'll do it for £49 then it was for nothing ! I know I've not got a 4k sub but I actually thought he was being a bit cheeky with that ! I've heard that it's £99 for the 1tb uhd box which is fair enough I suppose
Re: Sky Q lnb
@edgie700
I agree with @Chodley The agent was probably getting confused with a doorstep box swap which is a self install.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
Since Sky own the boxes in perpetuity , I think an install / delivery charge is ok but £100 to move their box to your house is cheeky. I paid £50 for the HDR upgrade which was worth it imho but really just involves them shipping me a box and shipping my older v1 Q back.
I like UHD but honestly I think HDR makes a bigger difference. The increased contrast, more realistic bright lights and wider range of colours really brings things to life. You can only get HDR with UHD on Sky though.
Re: Hdmi input on sky Q box
@edgie700 wrote:
I've seen pics online of sky Q boxes and noticed some have a HDMI input on the back , do they still have this ?
That was the v1 2TB ('Sky Silver') hardware back in 2016: it's never been clear what the Sky thinking was in specifying it that way.
Avatar for edgie700
Level 4 icon
@TimmyBGood shame because I could've plugged a DVD player in it
