Discussion topic: Sky Q box - Viewing card issues
Message posted on 29 Nov 2024 08:20 PM
When I turned on our sky box this evening we got this message - your viewing card is not activated - it was working fine last night
Message posted on 29 Nov 2024 08:30 PM
Re: Sky Q box - Viewing card issues
Hi @Dee241
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Take it out and give the chip a gentle wipe with a damp lint free cloth or E-cloth.
Ensure that it completely dry before you reinsert it chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Message posted on 29 Nov 2024 08:57 PM
Hi thanks for getting in touch
yes we have done all this and still nothing.
its like they have deactivated our account and I cannot get in touch with anyone - it was working perfectly last night - bill is paid - it's a mystery
Message posted on 29 Nov 2024 09:16 PM
Hi @Dee241
Have you rebooted since checking the Viewing card?
Message posted on 29 Nov 2024 09:20 PM
Hi
yes we have - a few times actually and still getting messsge 'your viewing card is no longer active' everything else on settings seems ok
Message posted on 29 Nov 2024 09:39 PM
@Dee241 wrote:
Hi
Hi @Dee241
Can you get into the Q box to try a Reset settings in the hidden menu?
