Discussion topic: Sky q box slow to play recorded programs
This message was authored by: Andy268
My sky q box has become slow to respond when going to play a recorded program, also when deleting after viewing.
I have tried a reset, also a power off and on.
I have also reset my Internet router as well.
Re: Sky q box slow to play recorded programs
Was that a Reset settings in the hidden menu @Andy268 ??
Avatar for Andy268
Yes it was
@Andy268 wrote:
Yes it was
Hi @Andy268
Have you checked your Disk space in Recordings - Manage?
Avatar for Andy268
Yeah there is loads of space. Only about 8 programs on there.
Assume you have checked your Q box software is up to date @Andy268 ?
Avatar for Andy268
Um no I haven't.  How do you do that?
I assumed it updated itself.
Hi @Andy268
First thing to do is check if the box is on the latest Software.
See following links for latest Software versions and how to update Q software
https://www.sky.com/help/articles/sky-software-updates
https://www.sky.com/help/articles/updating-sky-box-software
It does normally update itself
Avatar for Andy268
I did the update, will see if it made any difference tonight.
Thanks for the help.
If it remains unresponsive then it could be a sign of a failing hard disk.
Avatar for Andy268
OK, so it's still slow tonight.
So nothing has changed.
Any idea how I get an engineer to take a look?
Contact Sky directly @Andy268
