This discussion topic has been answered Discussion topic: Skq q. Ox is connected to the tv but no picture or sound
Message posted on 10 Sep 2024 09:14 PM
SKY Q Box is connected to the TV but get no sounds or picture and have restarted the box a few times now.
Message posted on 10 Sep 2024 09:28 PM
@jbutler wrote:
Hi, @oldfella many thanks for the quick response, I tried that and with a new HDMI lead and still the same issue. SKY remote allows me to turn on the box off and on.
Hi @jbutler
When you tried
Home 1 0 8 0 Home
was the Q box on with green led?
Also try rebooting the television.
Disconnect power lead for 30 secs and then reconnect to reboot the television.
Message posted on 10 Sep 2024 09:16 PM
Re: Skq q. Ox is connected to the tv but no picture or sound
Hi @jbutler
First make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
Message posted on 10 Sep 2024 09:23 PM
Hi @jbutler
When you tried
Home 1 0 8 0 Home
Message posted on 10 Sep 2024 09:34 PM
Hi @oldfella , the TV restart did the trick. Many thanks!
