5
This discussion topic has been answered Discussion topic: My sky q box has no sound
This message was authored by: Kathryn83
My sky q box is working as expected but has no sound, also tried the apps within sky and there is no sound on those either however, my tv sound is working. This is the 4th time this has happened and last time took days to come back
Avatar for Kathryn83
Level 0 icon
This message was authored by: Kathryn83 Answer
Re: My sky q box has no sound
Thank you! I found another suggestion to unplug both ends of the hdmi cable and power off the tv and sky box and it seems to have worked!
Hi @Kathryn83
Level 0 icon
This message was authored by: Iain67
No sound , have tried all hints and tips but still no sound
@Iain67
If you have not done so, may I suggest a full power down of your TV (unplug or switch off at mains)
We often find this restores sound for others
This message was authored by: tiptoptup1
This resolved mine issue after having tried everything else. So simple, but something I completely overlooked. Thank you buddy 😁
Answered - Go to Answer
