Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Message posted on 12 Aug 2024 04:32 PM
Re: Netflix has stopped working on 1 of 3 TV’s in house
I have moved your post to this large topic where this issue is being discussed in the Sky Q forum. There is a possible fix here in the second post:
Message posted on 12 Aug 2024 06:59 PM
Re: Netflix Won't Load / Spinning Circle
Actually I called Sky and after following some instructions over the phone it is now sorted and loaded as it should. He said problems have existed since Netflix upgrades and as I have an older sky package the apps on my box needed resetting. But result is it's fixed 👍
Message posted on 12 Aug 2024 07:35 PM
Re: Netflix: Red Spinning Circle on Launch
On step 7 - you say "sign out of Netflix on the Q box" how the heck do you do that?? You can't sign out of Netflix because the red circle is still spinning - ?? 🤔🙄🥴
Message posted on 12 Aug 2024 07:52 PM
Same, I can't do anything. Sky told me to watch Netflix on my app on the IPhone while going into another app like BBC I player, watch that for a few minutes then try the tv. This worked once or twice and hasn't done so since. I've been watching on my phone for about 2 weeks 🙄
Message posted on 12 Aug 2024 07:59 PM
You can ignore that so instead do this:
Reboot SkyQ box by turning off at the wall or plugging out for 1 minute.
Message posted on 12 Aug 2024 08:01 PM
Followed the instructions as per - at step 7 I just closed sky and rebooted the box (mains switch off for around 5 minutes) switched back on - Tried Netflix and 'behold' it's back on !! So, follow the instructions at the beginning of this thread but reboot the box at 7. Good luck !
Message posted on 12 Aug 2024 08:03 PM
I get the spinning circle on my SkyQ box but not on my three mini boxes.
Message posted on 12 Aug 2024 08:51 PM
Netflix hasn’t been loading for over two weeks. We’ve tried software updates
Netflix logo is showing, with red spinning circle below like it is trying to upload
Message posted on 12 Aug 2024 08:57 PM
Re: Netflix hasn’t been loading for over two weeks. We’ve tried software updates
Your post has been moved into a large thread discussing this very issue. Please see the post (number 2) currently showing as the answer.
Message posted on 12 Aug 2024 10:14 PM
in terms of reset it's the one that's posted further back in this thread. Basically signing out of the account on a mobile device and then switching off at the mains and switching back on again. It works but how ridiculous is that that you have to do it every few days?and in terms of tech problems taking time: if Sky and Netflix actually cared, they would sort it out as a priority. Does anyone from Sky actually look at this column? it reads as though this is unofficial Sky facility. Being it says sky.com the end. What is the status of this community? Does anyone from Sky actually look at this and try and resolve things? But they are just happy to take the subscription fee every month and let everyone stare at a red circle for literally hours on end instead of providing the service.
Message posted on 14 Aug 2024 08:05 AM
@Gee+o+Bee wrote:Followed the instructions as per - at step 7 I just closed sky and rebooted the box (mains switch off for around 5 minutes) switched back on - Tried Netflix and 'behold' it's back on !! So, follow the instructions at the beginning of this thread but reboot the box at 7. Good luck !
That's literally what it actually says to do
Where are people still seeing the mistake step 7 which got edited/fixed about 5 days ago?
Message posted on 14 Aug 2024 08:26 AM
Netflix app issue
Message posted on 14 Aug 2024 08:32 AM
Re: Netflix app issue
@elizabethlyson wrote:
It won't load, it is stuck on the load screen,
Do you mean you're just seeing a red spinning circle?
Message posted on 14 Aug 2024 09:19 AM
Hi Daniel, yes that's right, the spinning red circle.
Message posted on 14 Aug 2024 09:46 AM
Following steps 1-8 above works.
