2507
This discussion topic is read only This discussion topic has been answered Discussion topic: Netflix has encountered an error. Code: tvq-st-102
Locked
Re: Netflix: Red Spinning Circle on Launch
For clarity, click on your profile picture and then click on 'Account':-
 Then click on 'Manage access and devices':-
 Lastly, click on 'Sign out' for the device you want to remove:-
This will remove it immediately with no further dialogs. Clicking on the Netflix box from your Sky box should then automatically sign you in, although I had a message that it had a problem playing this title at the moment (Sweet Tooth S03E01 on the first advert).  I logged out of Netflix on the box and then let it sign back in by itself which resolved the issue.
@Anonymous wrote:
This all day long, I suspect a good few are still just logging out of Netflix.
I'm not sure - I mean I don't think you can get to the menu if you're stuck on the spinny circle, can you?
I just wish people would be more precise with their language as it burns a lot of time clarifying what they've actually done.
"I've tried everything" is particularly unhelpful
Online, not through the box.
Your last line is spot on though. "It's not working", "Help" and others are equally as pointless.
This message was authored by: Lynn2544
Re: Netflix red spinning circle
Same here ... why has this suddenly started happening !!! So annoying.  I have to kept turning my sky box off and restart just to watch Netflix!! Does not seem to be any response from sky on here about this issue but it is clearly an ongoing problem that is affecting quite a lot of customers !!
This message was authored by: Abbie30
I got told if I keep my storage below 60 percent it should no longer happen hope this helps , but we shouldn't be deleting our favourite shows for us to be able to watch Netflix x
This message was authored by: Fusionator
Worked it out. This started for me when I upgraded to 4k. Would load on everything bit skyQ. I downgraded to standard on Netflix and it works on sky again.
So clear answer is that the Q box isn't good enough to run it in 4k.
This message was authored by: Meems
I now do this every time! Rubbish!
The Q box is definitely showing it's age nowadays in little bits and bobs. This is why I and many others use the apps on the TV or other platform as the quality can be much better both in terms of picture and sound..
This message was authored by: CJ+237
This started happening to us (spinning red circle) about a month ago.
Followed the guidance provided but hasn't worked. Anyone else experiencing this issue?
Also, how do I log in to Netflix via their website as it doesn't recognise I have Netflix through SKY?
Err... Why do you think there's 79 pages in this thread? 🤔
As regards signng in online or through another app then I'll copy & paste another post from a different thread, credit to @Chodley
"You can't login to Netflix with your Sky credentials (i.e. password) but you can do a Netflix password reset, using your email from your SkyID, as long as your sky account has been set up and linked to Netflix."
This message was authored by: clcon
Netflix on sky q
Hi. Constantly now getting the issue of spinning red circle when trying to open netflix app on sky q. Have tried resetting etc and no luck
Re: Netflix on sky q
@clcon I have moved your post into the larger thread all about your problem have aread of it and you will find a post from a Sky employee post 1174 about what is happening
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This does work. Sadly, it seems that it needs resetting daily!
@Meems
Have a look at post 1174 in this thread from Sky staff copied here…
Hi, this is a known issue to us.
It is due to be resolved in our next software update.
Lisa - Sky Tech Team Expert
Except I use it in 4K all the time. V3 box, don't know if that makes a difference.
I'd missed that update from Lisa. Good news.
Locked
Answered - Go to Answer
