24 Sep 2023 07:54 PM
@MarkJ22 wrote:Yeah pretty much all TVs do these days. The issue here is that we all watch everything through our Sky Q box and for those of us on here who have posted it doesn't work sometimes.
I could watch NF on the TV but that requires pressing more buttons and it SHOULD just work through the Q box
Of course, mine only worked intermittently for a long while and I used the TVs App instead. It's just a little disingenuous to say they're paying for something that they can't use.
25 Sep 2023 10:33 PM
Help! Same issue for weeks - Netflix will not load and the circle just keeps going round and round. Very frustrating and thinking I'll get Netflix removed off my Sky package if this cannot be permanently resolved.
26 Sep 2023 09:33 AM
@Dee7 wrote:Help! Same issue for weeks - Netflix will not load and the circle just keeps going round and round. Very frustrating and thinking I'll get Netflix removed off my Sky package if this cannot be permanently resolved.
If you use Netflix and will continue using it surely the Sky Netflix subscription is lower than a separate sub? Just use the Smart TVs (or Amazon Firestick perhaps) version for now. You can always use it as a bargaining tool when your renewal comes around 🙂
I've had one of the Sky employees on here contact me again asking me to change a setting on the account so they can pass it back to the support team. My problem with Netflix disappeared or was resolved a couple of months back (so far anyway) but I won't discuss who and what was done yet as it may not help yourself or others and may just muddy the waters if it turns out not relevant.
Be assured that they are trying to track down what the issue is for those still affected.
(And no, I don't and never have worked for Sky 😉 )
26 Sep 2023 09:41 AM
Interesting that you have a direct connection to the TV and have had issues
Mine has been working the past few days so it cannot be a connection issue!!
I don't see a problem sharing your fix. It may help someone and is at least another thing to try if people are still stuck at the red whirrrr of death
26 Sep 2023 10:03 AM
@MarkJ22 wrote:Interesting that you have a direct connection to the TV and have had issues
Actually, fair point although I don't know if anything was done at all the first time I was contacted or whether that was coincidental.
I've just gone back over what was requested and checked nothing has changed on the Q box and it's still the same Mac address and Netflix ESN details. Yesterday I was asked to log into the Netflix account online, go to the "Account" link and turn off "Test Participation" at the bottom if it was on (it was).
I would hazard a guess that the request for the Mac address and Netflix ESN details from the Q box allowed them to remotely monitor, if not access Netflix directly on my box with presumably logs to pour over.
Turning off "Test Participation" is possibly to just remove one variable to help track the issue down.
28 Sep 2023 07:53 AM
Just to add a workaround...
It isn't necessary to unplug the box when Netflix gets stuck.
Press the back button and exit Netflix.
Open the BBC iPlayer App and then exit out of that.
Open Netflix again... now working again.
Usually works for a few days...
29 Sep 2023 12:13 PM
How can i get this question in front of a sky employee?
29 Sep 2023 12:20 PM
Try the following:
To enter hidden menu press Home and navigate down to Settings but do not select Settings. With Settings highlighted press 0 0 1 Select. then highlight Refresh all Apps on this box.
Sky Q boxes are quite long in the tooth now and were never initially designed to host apps so they do tend to be slow and prone to locking up.
For a better Netflix experience I'd recommend using the Netflix app built into your smart TV (if you have one) or a dedicated streaming device such as a Firestick, Roku or Apple TV 4K box.
29 Sep 2023 12:25 PM
Thanks robert
as mentioned in my post however, the "refresh apps" is no longer on that hidden menu.
I really need to speak to someone from sky about this. I would have expected a response by now as it has been 5 days since I posted
29 Sep 2023 12:28 PM - last edited: 29 Sep 2023 12:28 PM
Posted by a Superuser, not a Sky employee. Find out moreSky employees have responded (or been quoted) in the other threads on this subject iirc
29 Sep 2023 12:54 PM
@Collinsc wrote:Thanks robert
Refresh apps has not been removed. From the hidden menu in Sky Q.
To refresh your apps;
On Sky Q:
The refresh can take 24 hours to complete.
Also, have a browse of the guidance here;
https://www.sky.com/help/articles/apps-on-sky-q-and-glass
29 Sep 2023 01:07 PM
Thank you!
yes I was missing a step!
still need someone from sky now though to talk to about the Netflix issues
29 Sep 2023 01:19 PM
@Collinsc wrote:Thank you!
After reading link above, not just doing a refresh of the apps.
What problems are you getting with Netflix on Sky Q.
Any error messages?
29 Sep 2023 01:36 PM
I'm afraid there are no error messages. The Netflix screen appears and that is all
29 Sep 2023 03:01 PM - last edited: 29 Sep 2023 03:02 PM
Posted by a Sky employeeHi all,
As @Colin0000 has advised, anyone still having the Netflix app not loading (spinning red circle) please try the below steps to resolve the issue. If you can advise if this resolves the issue for you or not and we can feed this back to the support teams:
This will involve logging into Netflix on a webpage to amend settings.
Once you log in, click on My Account -> scroll to the bottom and you'll see the below options:
Click on "Test Participation" and if the feature is on, please turn this off. If you can go onto the app on your Q box and let me know if this loads properly.
Thank you.
Note: marked as answer to be easier to find.
