Discussion topic: Needing a new sky q remote
This message was authored by: Kyle3
Hello I'm in need of a new sky q remote just nothing is working
Re: Needing a new sky q remote
As you are asking in the Sky Protect section, assume you have  the Sky Protect device insurance.
You can ring to get a new remote via the Sky Protect device insurance number here;
https://www.sky.com/help/home/sky-protect/sky-protect-device-insurance/articles/sky-protect-frequent...
Or,
You can order a replacement Sky Q remote via an a online form from within Sky help, by clicking on the I need help button.
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-q-equipment/fixing-my-remote/artic...
In the meantime,
There's a virtual Sky Q remote on the Sky Go app.
You can use this whilst waiting for a replacement remote.
First get set up with Sky Go. Then:
  1. Open the Sky Go app
  2. Make sure Sky Go is connected to your Sky Q box
  3. Press the Settings button in the top left corner
  4. Under Devices, select Sky Q remote
  5. The Virtual Remote will open - you can select which Sky Q or Sky Q Mini box you want to control.
This message was authored by: XtineSky8900
Yes I need a new one
ASAP please
@XtineSky8900
This is a customer ➡️ customer discussion forum where we try to help other Sky customers. You aren’t speaking to Sky staff by posting on here.
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
In the meantime if you have an android or Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
This message was authored by: Pattywheats
Yes please
@Pattywheats wrote:
Yes please
@Pattywheats
You aren’t contacting Sky here. This is a customer ▶️ customer discussion forum where we try to help other customers.
The route to getting a new remote if yours is faulty is in the post immediately above yours.
This message was authored by: Sandhead1
Remote not working with box , not lighting up box , remote not working at all.
@Sandhead1
The thread already contains the advice you're looking for. Post 5 for example.
This message was authored by: Me134
Is the Q box not turning on at all? If not it may be a recent issue with a software update that affects the box, not the remote.
https://helpforum.sky.com/t5/Sky-Q/This-programme-is-no-longer-available/td-p/5265526/page/9
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
This message was authored by: Judylee123
Yes unable to open Sky Remote to change batteries, I am still under warranty
Slide the cover off.
