Discussion topic: Needing a new sky q remote
Message posted on 27 Apr 2025 04:35 PM
Hello I'm in need of a new sky q remote just nothing is working
Message posted on 27 Apr 2025 04:55 PM
Re: Needing a new sky q remote
As you are asking in the Sky Protect section, assume you have the Sky Protect device insurance.
You can ring to get a new remote via the Sky Protect device insurance number here;
Or,
You can order a replacement Sky Q remote via an a online form from within Sky help, by clicking on the I need help button.
In the meantime,
There's a virtual Sky Q remote on the Sky Go app.
You can use this whilst waiting for a replacement remote.
First get set up with Sky Go. Then:
Open the Sky Go app
Make sure Sky Go is connected to your Sky Q box
Press the Settings button in the top left corner
Under Devices, select Sky Q remote
The Virtual Remote will open - you can select which Sky Q or Sky Q Mini box you want to control.
Message posted on 19 Oct 2025 10:55 PM
Yes I need a new one
Message posted on 19 Oct 2025 11:02 PM
ASAP please
Message posted on 20 Oct 2025 05:15 AM
@XtineSky8900
This is a customer ➡️ customer discussion forum where we try to help other Sky customers. You aren’t speaking to Sky staff by posting on here.
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
In the meantime if you have an android or Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
Message posted on 09 Dec 2025 10:48 PM
Yes please
Message posted on 09 Dec 2025 10:58 PM
@Pattywheats wrote:
Yes please
@Pattywheats
You aren’t contacting Sky here. This is a customer ▶️ customer discussion forum where we try to help other customers.
The route to getting a new remote if yours is faulty is in the post immediately above yours.
Message posted on 13 May 2026 10:46 PM
Remote not working with box , not lighting up box , remote not working at all.
Message posted on 14 May 2026 04:54 AM
The thread already contains the advice you're looking for. Post 5 for example.
Message posted on 14 May 2026 10:06 AM
@Sandhead1 wrote:Remote not working with box , not lighting up box , remote not working at all.
Is the Q box not turning on at all? If not it may be a recent issue with a software update that affects the box, not the remote.
https://helpforum.sky.com/t5/Sky-Q/This-programme-is-no-longer-available/td-p/5265526/page/9
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Message posted on 16 May 2026 08:40 AM
Yes unable to open Sky Remote to change batteries, I am still under warranty
@Kyle3 wrote:Hello I'm in need of a new sky q remote just nothing is working
Message posted on 16 May 2026 08:56 AM
@Judylee123 wrote:Yes unable to open Sky Remote to change batteries, I am still under warranty
Slide the cover off.
Message posted on 13 Oct 2026 01:28 PM
I need a new sky remote please
Message posted on 13 Oct 2026 01:31 PM
Quite a few of the posts on the thread you've added to explain the process and provide the relevant link.
