Discussion topic: My sky q electrical interference
Message posted on 04 Jan 2024 06:59 AM
My sky Q box cuts out every time a light switch or any electrical equipment in the house is turned off or on
Message posted on 04 Jan 2024 07:15 AM
Re: My sky q electrical interference
Cuts out?
Message posted on 04 Jan 2024 07:20 AM
The screen turns black for a second or turns black for 5 seconds with a white spinning circle non of my other inputs I.e. my fire stick has this problem
Message posted on 04 Jan 2024 11:46 AM
I would get an electrician to check your wiring.
Message posted on 04 Jan 2024 11:50 AM
Don't think so that's my profession
i do believe it's a frequency issue with the sky Q box
Message posted on 04 Jan 2024 12:46 PM
Fair enough but never happens to me and I would assume all the EM shielding is the same for every customer.
Unless your HDMI cable is routed parallel to a ring main or something?
Message posted on 18 Oct 2024 06:24 PM
Did you get find the route of this problem as mine has started to do the same? I have a hdmi extender cable coming from the main 4k cable so not sure if that is causing the problem.
Message posted on 19 Oct 2024 06:46 AM
It maybe the hdmi extender or the cable to it.
They can suffer from interference that will cause audio and video glitches.
Try swapping them out and try the Sky supplied hdmi cable or a high speed equivalent on its own to test.
Message posted on 19 Oct 2024 07:10 AM
I did find the route of the problem it was a detestation of the HDMI cable which I replaced and I have had no issues since then
The lesson I have learned is DONT BUY CHEAP
