Discussion topic: Sky Q downloading issue
This message was authored by: Super_Mario
Hi,
I swapped to you fibre several months ago and have been running with no issues. I've recently had a new q box as the previous one failed.
On the new box it frequently won't load any program preview pictures/menus and fails to download any media. When it is working it's so laggy.
I was fault finding with someone on the phone before the call getting dropped after 30 mins. They suggested I'd need to get in touch with my ISP but as everything was working fine before this new box I can't see that as the issue?
any pointers would be appreciated.
Re: Sky Q downloading issue
@Super_Mario wrote:
Hi,
Hi @Super_Mario
Avatar for Super_Mario
Tried resetting the router before posting this. Everything else on the wifi is working fine.
It did seem to resolve itself but today the downloads just get stuck at 1% or i get 'Failed, Remote network problem'
before getting a replacement box I'd never had this issue.
This message was authored by: Kelly166
Did you find a resolution.  Mine won't even download or play and catch up tv
I did actually.
I changed standby mode to none and haven't had a problem since.
Downloads still take too long though even with 1.2Gbps internet speed.
