This discussion topic has been answered Discussion topic: Deleted Recordings
Message posted on 24 Mar 2024 01:24 PM
When I delete a recording it goes into Manage > Deleted
This usually gets clogged up quite quickly for me, is there a way for these to be automatically deleted instead of having to manually delete them? Or are they automatically deleted after a month or so?
Message posted on 25 Mar 2024 02:38 PM
@FullLoader wrote:
Ok so if I keep adding to the deleted recordings would they just get automatically deleted at some point? I never keep recordings, I always delete them once I've finished watching them so I never run out of space in Most recent.
You don't really add to the deleted recordings as such - if the space has not been reused they appear in the list allowing you to restore them.
The system will use the space when needed so when it uses the space from a deleted recording, it will no longer be listed
Thus you really don't have to worry about how many entries are listed in the deleted recordings section
There is no need to go in and select permanently delete
As I said most customers probably never even go into the Manage - Deleted section
Message posted on 24 Mar 2024 01:28 PM - last edited: 24 Mar 2024 01:29 PM
Re: Deleted Recordings
You don't have to delete from the deleted list - the system automatically uses the space when needed.
Most people probably never go into the Manage - Deleted option unless it is restore something accidentally deleted
Message posted on 24 Mar 2024 03:16 PM
But doesn't it take up space if you don't delete from the deleted list?
I've deleted programmes from there and noticed my disk space goes up after I've deleted programmes.
Message posted on 24 Mar 2024 03:21 PM
@FullLoader No deleting from deleted won't get you anymore genuine space
Message posted on 25 Mar 2024 09:22 AM
So effectively there's no point deleting from deleted? I could've sworn it gave you more space?
Message posted on 25 Mar 2024 09:55 AM
@FullLoader No real point
Deleting permanently from the Deleted section can sometimes cause showing a decrease in space used but leaving deleted items in the list just means the space is not always fully marked as released but is availble for use & it does not matter as the system will use it when needed
Message posted on 25 Mar 2024 02:26 PM
Message posted on 25 Mar 2024 02:36 PM
The box will automatically remove the oldest deleted recordings when it needs the space. There's no advantage to deleting them manually.
Message posted on 25 Mar 2024 09:30 PM
Thanks, in that case I will just leave manage deleted section.
