Discussion topic: Sky Door Chime - not syncing
Message posted on 02 Sep 2023 05:37 PM
Re: Sky Door Chime - not syncing
Has anyone found a solution to this problem yet. On my second chime and tried for weeks (probably about 100 times!)
Tried resetting everything that can be reset (numerous times), app permissions fine. Latest advice was to switch off data roaming but nothing is working. Lots of emails and calls but feel like I might need to give up!
Everything else works but just cannot get the chime to connect
Message posted on 24 Sep 2023 05:58 PM
Doorbell chime won’t sync
I'm on my 2nd chime from Sky and same problem...won't connect.
It would do everything right then it always show error... no internet connection
All the other items ( not doorbell as awaiting to get the chime working) got connected and working fine.
Message posted on 24 Sep 2023 06:00 PM
I'm currently experiencing the same problem as you described
Message posted on 25 Sep 2023 06:47 PM
Where is the live chat function?
Message posted on 26 Sep 2023 10:35 AM
@AL579 wrote:Where is the live chat function?
You will find all the Sky Protect support options, by hitting the ?, top right on the Home Screen and dropping to the bottom and clicking the blue Support link.
An email address is listed there to flag support, if you do not see any message options.
Message posted on 26 Sep 2023 06:35 PM
Re: Doorbell chime won’t sync
Hi
Having tried everything suggested the only way I got it too work was to bring a really old iphone back to life and do it from that (the blocker seemed to be modern iphone). When back to old phone it did it straight away. There were still issues updating firmware which took some sorting (update the chime first not the doorbell even though the app guides you the other way round).
Good luck
Message posted on 27 Sep 2023 03:54 PM
Something else to try if you are having trouble syncing or viewing your doorbell.
From the Sky Protect app, select the video doorbell, click on the gear button top right and scroll down to click on reboot the device. It takes a short while to do this, maybe a few minutes.
Try the doorbell live view again or try resynching if it's not resynched.
Message posted on 27 Sep 2023 10:20 PM
Sky has sent another doorbell and chime (3rd now) so will try your suggestion.
I just don't understand why a big company as Sky having their customers going through so much problems with their chimes and doorbells. It's not a recent issue and should have been sorted by now. Sky has the money to have corrected the problem ages ago.
Message posted on 28 Sep 2023 06:50 AM
@Frannie2 wrote:Sky has sent another doorbell and chime (3rd now) so will try your suggestion.
Must admit, I have had no problems.
Mine is now coming up to three months of constant use.
Have found the door bell has needed charging once a month, so been consistent on that.
The doorbell gets good use and reports and captures well, day and night.
Had no issues with the indoor camera or it's sensor base.
All the other kit has been reliable, all door/leak/contact sensors reporting perfectly.
The arm and disarm works reliably too, when away from house.
Hope you get this one setup as it's described through the app, starting with the Chime.
Make sure, you give the Doorbell a full charge before connecting up to the Chime. It needs a good many hours if it's low, perhaps leaving it to charge overnight. Charge it from the Chime usb port using the supplied usb flat cable.
Message posted on 01 Oct 2023 05:48 PM
I received mine yesterday same problem ringer will not sync very frustrating I have tryed everything
Message posted on 03 Oct 2023 08:51 PM
I have the agsact same issue very frustrating every else connects except doorbbell
Message posted on 06 Oct 2023 05:39 AM
The indoor camera is rubbish! I got the same error message as you did, uninstalled it and I have been trying to reinstall it to no avail. Without exaggerating, I've tried at least 20 times! I've even spoken to the help team and they sent a new indoor camera which will not connect! I'm sure it's not my network because the video doorbell works fine. It's very frustrating and I'm beginning to think a waste of money. I should cancel the subscription and buy another product methinks...
Message posted on 17 Oct 2023 06:57 AM
Get an old phone, iPad or laptop and download the Sky Protect app onto the old device...then set up doorbell and chime via that device....once devices are setup, you will be able to access it on your current phone, iPad or laptop (ensure you download the Sky Protect app on your current smartphone, iPad or laptop)
Message posted on 19 Oct 2023 12:52 PM
Is there any way I can contact the technical department? I'm having a problem with the chime; it keeps flashing blue. I reset the gadget and the internet. I eventually uninstalled the video doorbell from the account, and now I can't add it back in or connect to it. I contacted 150 customer service and the Sky Protect Sale team, both of which were completely useless. Please assist.
Message posted on 19 Oct 2023 12:59 PM
@Lumi wrote:Is there any way I can contact the technical department? I'm having a problem with the chime; it keeps flashing blue. I reset the gadget and the internet. I eventually uninstalled the video doorbell from the account, and now I can't add it back in or connect to it. I contacted 150 customer service and the Sky Protect Sale team, both of which were completely useless. Please assist.
I've answered this in your other post.
