Discussion topic: Sky Door Chime - not syncing
Message posted on 10 Aug 2023 10:18 PM
Re: Sky Door Chime - not syncing
Yes I'm still waiting on a reply as well about what I'm meant to do. I haven't tried the rest of the kit, didn't see the point if it's not all working properly.
Message posted on 11 Aug 2023 04:00 PM
No there isn't!!!
Message posted on
11 Aug 2023
04:07 PM
- last edited:
16 Aug 2023
09:19 AM
by
KevNewMedia
Same issue hrs wasted with something went wrong msg everytime trying sync bell with chime. [content removed] How have they not fixed this!!!! I
Moderator note: language removed
Message posted on 11 Aug 2023 04:27 PM
I've just been told there is a bug in the software and the second line tech team are trying to fix it. So it wasn't user error!
Message posted on 11 Aug 2023 04:37 PM
Again??!! Same aa last month ams before then. Please let me know qhw it might just possibly work
Message posted on 11 Aug 2023 05:00 PM
Yes I'll let you know what they do for me.
Message posted on 11 Aug 2023 05:57 PM
Dylan from sky protect was very helpful and sorted out the problem, after suggesting a couple of solutions that didn't work I tried looking at my mobile permissions they weren't all turned on. Everything worked fine after that.
Message posted on 11 Aug 2023 06:17 PM
Dylan has emailed me but nothing in few hr. Took your advice a give full permissions to the app. See if helps
Message posted on 11 Aug 2023 06:35 PM
That's who I've sent over 50 emails to trying to sort it. Yes he's helpful but he hasn't solved this issue and had to escalate.
Message posted on 11 Aug 2023 06:42 PM
Dylan responded to my email I sent at 16:30 yesterday at 08:15 this morning and replied really quickly all day until about 15:30 when I asked how to charge the doorbell- he said to plug it into the chime and turn it off.
Message posted on 11 Aug 2023 07:01 PM
He's helpful, I've been speaking to him via email all week. Hence over 50 emails but he cannot resolve my issue. There is a software issue with the chimes and doorbells, turning it on and off, resetting it, trying different devices, I've done it all with Dylans advice and neither of us could sort it. That's why he escalated it, I've been told by him that the tech team are trying to find a fix as it could effect others.
Message posted on 20 Aug 2023 12:49 PM
Please could you explain how I turn the 5 Getz off on the router, Sky router?
Message posted on 22 Aug 2023 10:39 PM
are you meaning turning off sky 5ghz compatibility and using 2.4ghz only?
Message posted on 23 Aug 2023 06:34 AM
@NBSUSIE it shouldn't be required to change the wifi set-up on any Sky hub to install the Sky Protect kit AFAIK. However the following instructions will split the bands on the.black Sky hubs Split Sky WiFi bands
The very latest white Wifi Max hub is different and you cannot split the wifi bands. You can only turn off either or both bands in the My Sky app but turning off the 5GHz band will severly reduce speeds. To get Wifi6 to work properly you need both bands on.
Message posted on 23 Aug 2023 08:43 AM
The chimne for the video doorbell, plugs into your sky router with an ethernet cable.
The chime does not connect over wifi.
Once the chime is connected you can then move on to pairing your video doorbell to the chime.
Follow the instructions by clicking on + add device for the video doorbell, it will first guide you through setting up the chime via ethernet and once the chime is showing a blue connection light you can then pair the video doorbell to the chime.
None of the Sky protect kit requires any splitting of your router bands.
