04 Nov 2023 08:39 AM
The support is poor I'm in the same situation the door bell will not connect been on the phone twice yesterday and was told I would have a firm ware update fone then moaned again as still not connecting!
was told in a email
Hi Gavin
Thank you for reaching out, sorry you are having issues installing. We have been made aware in the last 30 minutes that a key service is down, that may be limiting installation of the chime and/or doorbell for some users. Can i ask, whilst we investigate you not try installation. The team are working on this right now and hope to have services restored shortly"
still can't connect
05 Nov 2023 10:17 AM
Is there an update with regards the issues with syncing the doorbell, I am still unable to get mine to sync
12 Nov 2023 11:36 PM
I had this exact issue took me allll day.
I didn't realise the chime has to be flashing yellow and blue aswell as the doorbell. I unplugged the chime, reset it in the side then it connected straight away. Hope this helps someone
27 Nov 2023 04:36 PM
I am having the same problem. Chime has synced but repeated efforts to sync the bell do not work. Does anyone have any advice please? Thanks
28 Nov 2023 02:43 PM
Same problem with mine the camera doesnt flash between blue and yellow, going to fully charge overnight and try again tomorrow.
28 Nov 2023 03:19 PM
Posted by a Superuser, not a Sky employee. Find out moreIf your doorbell is not flashing blue/ yellow, try switching off the doorbell with the switch in the rear of the doorbell under the flap, leaving off for at least ten minutes.
Switch on and recharge via the chime using the supplied usb cable fo about 6-8 hours or overnight.
28 Nov 2023 05:23 PM
Thanks for this. I have been getting the yellow and blue flashing lights on the doorbell when attempting to sync with the chimer but it just never completes properly. I'll charge fully overnight and try again. Is there another process for this scenario where the bkue & yellow lights are flashing?
29 Nov 2023 09:04 AM
@JeremySh wrote:Is there another process for this scenario where the bkue & yellow lights are flashing?
No thats just during charging.
29 Nov 2023 10:21 AM
Left on charge overnight tried again this morning and all I get is a solid yellow on the video doorbell. Chime flashes as expected but no joy with the doorbell.
Thought of what to do next?
29 Nov 2023 11:01 AM
@Richard+Westwood wrote:Left on charge overnight tried again this morning and all I get is a solid yellow on the video doorbell. Chime flashes as expected but no joy with the doorbell.
Did you try the switch off with the switch on the doorbell as I mentioned a few posts up.
29 Nov 2023 11:18 AM
Yes not in contact with Sky Protect via email, doing a reset on the Chime and will try and resync.
30 Nov 2023 11:01 AM
My issue has now been resolved during a call with Sky this morning.
I had fully charged the ringer earlier in the week as well as resetting the chimer and the two were still not syncing with each other. During the call today though I resynced the chimer but set it up as a new chimer in the app (there is an option for this) and then went through the normal steps of syncing both devices and this solved it. Hope that helps.
01 Dec 2023 07:50 PM
So the video doorbell still will not connect and now the indoor camera has failed not impressed so far awaiting an update from Sky Protect via email.
