107
This discussion topic has been answered Discussion topic: Glass/Stream: There is a technical fault, please try again later/latency when changing channels
This message was authored by: LFC1981
I've been getting this error message repeatadly this morning. Anyone else having issues? I have a sky glass 55 inch gen 1
Moderator note: subject of thread updated to better reflect the conversation
This message was authored by: KevNewMedia Answer
Re: Glass/Stream: There is a technical fault, please try again later/latency when changing channels
Posted by a Sky employee
Hi Everyone
Thank you for your patience. Our support teams have advised that the problem has now been resolved.
If you are still having problems, can you restart your Glass TV or Stream Puck. We appreciate that you've used the Community to help resolve the problem and hope that you continue to use this service!
Kev
Community Manager
This message was authored by: Ren12345
Re: There is a technical fault, please try again later
Yes same with my Gen 1 Sky Glass. Turned on and first said no network connection but there was. Then ITV wouldn't work - technical fault and keeps coming up sporadically. Can still here the programme but the picture goes.
We only had an issue 2 weeks ago with no mainstream channels, so disappointing to have something similar so soon after.
This message was authored by: carlights
Yes the same problem here which is so annoying as we had this problem a couple of weeks ago as well
This message was authored by: Scott217
Tv not wotking
My sky puck is not working.
i have performed the checks on my WiFi and there is no problem, speed is good. All I'm getting on my tv is "technical fault please try later"
I have been through all sky's so called online help and nothing works. How do I get my tv back up and running?
Not impressed with sky as this is not the first problem I have had recently with my streaming services
This message was authored by: karl+mufc
Yep.
same here.
glass gen 2 55inch
This message was authored by: Hannah1192
Same issue here
This message was authored by: Martyn+A+K
I have the same message. Is this a reception issue due to weather?
This message was authored by: Dfwood
Re: Tv not wotking
Appears to be a Sky issue, as I have the same banner displaying here and unable to change channels, etc. so stuck with the news
This message was authored by: _lisap-
Technical fault
I keep getting a technical fault try later message when trying to watch something
This message was authored by: PaulB1969
Yep, on a fairly new Gen2 , going to check my pucks and old Gen1 soon , fibre broadband is fine ( Sky ) , WiFi is fine so not sure if there was a software drop last night. Have done a power cycle and a reset through settings, hoping it's a blip
Sky Glass (S-43") , 3 pucks, Sky Broadband Ultrafast (FTTP) 1 Gbps , 3 Sky Max Pods
This message was authored by: April7
Re: Technical fault
I have the same I can't seem to swap channels over
This message was authored by: Clennell2024
Re: Technical fault
I keep getting this has been happening all morning. Have you managed to fix the issue?
This message was authored by: Nigel19076
yes i am getting exactly the same message, my apps work fine.
Tim
This message was authored by: Top+Driver
Sky stream here sane issues
This message was authored by: Bishbosh1979
Sky glasss not working say technocal issues
Sky glass not working this morning at allnsays technical issues
Answered - Go to Answer
