Discussion topic: Glass/Stream: There is a technical fault, please try again later/latency when changing channels
Message posted on 09 Dec 2025 08:00 AM
Re: Technical fault
Same here! I thought it was an issue with my Stream but seemingly not. I'm in Worcestershire
Re: There is a technical fault, please try again later
This is happening more and more frequently. Its hardly a stable service.
Message posted on 09 Dec 2025 08:01 AM
I've had the same issue all morning saying Technical fault in Manchester area
Message posted on 09 Dec 2025 08:03 AM
Re: Technical fault
Essex . Same problem on Sky Glass .Anyone found any answers from Sky yet?
Message posted on 09 Dec 2025 08:05 AM
Re: Technical fault
Same problem. West Yorkshire!
Message posted on 09 Dec 2025 08:06 AM
Re: Technical fault
Same, technical fault and blue screen message.
tried power off and hard reset. Tried WiFi reset. Checked WiFi service if 1gb fibre 👍
sky service checker says no faults currently.
Message posted on 09 Dec 2025 08:08 AM
Sky stream technical fault
We had the sky stream installed yesterday with 500 mb internet but this morning it keeps coming up with a blue screen saying there is a technical fault please try again later
downdetector is ramping up with reports , mine has gone yet again so turned everything off. Off to work anyway , see how the land lies later.
Re: Technical fault
So I did the switch off at plug waited reconnected and it's still doing it 🤬
Message posted on 09 Dec 2025 08:10 AM
Re: Technical fault
It looks as though it maybe a country wide problem. We are in the South West and it has been intermittent since I switched on the TV at 05.30 this morning g.
Morning @KevNewMedia , I'm still lurking around 😁
FWIW, Restarts not helping for me. Happy to help where I can if you need anything checking, as you know.
Message posted on 09 Dec 2025 08:11 AM
Message posted on 09 Dec 2025 08:13 AM
Re: Sky stream technical fault
I have moved your post from the Sky Q board into a thread discussing this issue which is affecting Stream and Glass. See the post currently marked as the answer.
Message posted on 09 Dec 2025 08:15 AM
Re: Technical fault
Same issue, rebooted WiFi & box, to no success, sky app reports no issues in the area.
Re: Glass/Stream: There is a technical fault, please try again later/latency when changing channels
