Discussion topic: Glass/Stream: There is a technical fault, please try again later/latency when changing channels
Message posted on 09 Dec 2025 07:38 AM
Re: There is a technical fault, please try again later
Exactly the same issues. Internet working perfectly. Sky stream technical fault on loads of channels. This is happening far to often.
Message posted on 09 Dec 2025 07:39 AM
Re: Technical fault
Same problem
Message posted on 09 Dec 2025 07:40 AM
Re: Technical fault
i am also getting the same problem i live on the sussex coast is just in this area
I'm also having this issue. On the app it says I have a broadband issues but then when I go through the checker, it says the broadband is fine. I had this same problem earlier this year after an update was sent to sky glass. Sky tried to say I needed to buy a new TV but then after arguing for months that the issue had only started with their update, it was suddenly repaired. I do hope it's not the same issue!
Message posted on 09 Dec 2025 07:41 AM
Re: Technical fault
I'm in the SW so seems it's across the network
Message posted on 09 Dec 2025 07:44 AM - last edited: 09 Dec 2025 07:46 AM
Re: Tv not wotking
Message posted on 09 Dec 2025 07:45 AM
Ok , had the same issue on all device. Powered all down , restarted pucks first then glass and seems better now. Whether it's rectified while I was doing all this I'm not sure.
Message posted on 09 Dec 2025 07:47 AM
Re: Tv not wotking
Also, the Downdetector site is showing a spike in user reports of an issue with Sky
Message posted on 09 Dec 2025 07:48 AM
Re: Tv not wotking
M having the same problem I've turned everything on and off again. No help from Sky as they dont let you talk to the tech team until 8am. I guess we'll have to wait for them to wake up amd fix it. Very annoying. On both my TV's
Re: Technical fault
Me too been going on since 5.30 driving me nuts !
Message posted on 09 Dec 2025 07:56 AM - last edited: 09 Dec 2025 08:04 AM
Re: Tv not wotking
Sky are aware of this and a team are working to resolve it. It's affected Glass and Stream customers.
Message posted on 09 Dec 2025 07:56 AM - last edited: 09 Dec 2025 08:05 AM
Hi Everyone
Thank you for highlighting this problem; we are sorry and apologise for any inconvenience.
Our support teams are investigating the problem and when we have more information, we'll let you know.
Workaround:
Some Community members have discovered that a restart of the equipment has helped to clear the problem.
To understand the extent of this issue, I've merged some posts into the one thread. I'll be marking the thread as answered, so that anyone new to the thread knows we're working on it, and they don't have to read every post.
Kev
Community Manager
Re: Tv not wotking
@Hellsbells387 wrote:M having the same problem I've turned everything on and off again. No help from Sky as they dont let you talk to the tech team until 8am. I guess we'll have to wait for them to wake up amd fix it. Very annoying. On both my TV's
Have you tried rebooting the Sky Stream box @Hellsbells387
Message posted on 09 Dec 2025 07:59 AM
