Discussion topic: SKY GO Desktop App Won't Load/Open
Message posted on 26 May 2018 11:37 AM
Re: SKY GO Desktop App Won't Load/Open
I still cannot make the Sky Go app work on my Lenovo (windows 10 64 bit) but I had an inspired moment and tried it on my smaller HP tablet (Spectre x2 detachable) which runs on Windows 10 Home and with a 64 bit OS - and guess what? The installation and the damn app works! No problem at all. I totally don't get it and this is a compete farce but at least I got it to work on ONE of my laptops so that's something. Just thought I let you all know how random this seems to be!!
Message posted on 26 May 2018 12:34 PM
Another unhappy Sky user . App works fine on my phone and PS4 but not on my laptop. Itjust loads to a blank screen, Is there any real Desktop tema in Sky I can talk to , as I cant face spending an hour talking to somebody who just wants me to reboot the pc and reinstall it again ?
Its like Skydont want people to really use this , as it wont even work on Firefox / Chrome.....
Message posted on 26 May 2018 01:22 PM
Did you try this for the blank screen issue:
http://helpforum.sky.com/t5/Sky-Go-Apps/New-SKY-GO-app/m-p/2828028/highlight/true#M57762
Message posted on 04 Jun 2018 05:22 PM
They admitted they mucked up and dont know how to fix it to me.
Obvious compensation is due, make sure you all get it
Message posted on 04 Jun 2018 08:36 PM
Same tried everything , still wont work
Message posted on 04 Jun 2018 11:49 PM
It's been said that the problems with Sky Go could be due to your A/V software. So try excluding all of the files in "AppData > Local > Cisco", "AppData > LocalLow > Cisco", and "AppData > Roaming. > Sky Go" and see if Sky Go then works. If Sky Go does not work, try safe mode with networking and see if Sky Go works. If Sky Go does work in safe mode, try stopping everything from running that runs at startup one at a tiome until Sky Go works,
Message posted on 13 Jul 2018 08:02 PM
After seeing this reply, I went to control panel and uninstalled the CISCO videoguard and now everything is working OK. Didn't do anything else
Message posted on 13 Jul 2018 08:10 PM
@goonerlotty wrote:After seeing this reply, I went to control panel and uninstalled the CISCO videoguard and now everything is working OK. Didn't do anything else
It was reinstalled by Sky Go.
Message posted on 21 Jul 2018 10:43 PM
Yes, same happened to me next time I used it. Back to square one
Message posted on 19 Aug 2018 09:05 PM
Have had the exact same problem (on mac). Spent 2 hour and 3 hour stints on sky's service support chat assistant, whilst simultaneously being on hold for +1hour without any answer. So frustrating! ...and so unhelpful!
Message posted on 23 Aug 2018 11:46 AM
I'm Glad I'm not the only one.
What are we paying for.
I can't run sky go on my PC either.
I get the message "Installation Failed to complete in a timely mannor"
It just WON'T WORK.
COME ON SKY GET YOU FINGER OUT!
Message posted on 23 Aug 2018 11:48 AM
Oh the was meant to say "Initiallisation"
Message posted on 23 Aug 2018 01:17 PM
Follow the instructions here, you can ignore the bit about the time and date. After you have done that make sure anything Sky related is uninstalled from your PC and do a reboot before installing the app again.
Message posted on 23 Aug 2018 01:28 PM
That error of installing in a timely manner is easily fixed by installing as admin and then running as admin.
Message posted on 23 Aug 2018 04:05 PM
I HAve Tried EVERYTHING and the SKY GO App just refuses to work.
