107
This discussion topic is read only This discussion topic has been answered Discussion topic: Where has CNN news gone my box saying no signal for this channel ?
This message was authored by: Arthur2019
Has anyone else had problems. We can’t get CNN news
Avatar for Arthur2019
This message was authored by: Arthur2019 Answer
Re: Where has CNN news gone my box saying no signal for this channel ?
LukeinLondon we just turned ours off at the plug waited 20 seconds ish and now it’s back. Very strange but it worked
Locked
Fine here, so not a broadcast issue. What exactly does the on screen error message say?
It’s fine now thanks I made him power it totally down and it’s come back 👍🏻
This message was authored by: LukeinLondon
Also here, no cnn.  And it’s the ONLY channel I’m not getting which is very annoying as I watch it the most! Do we know why this happens occasionally &  affects only one channel CNN?
This message was authored by: Pindar
Same, it's been out since lunchtime 07/08
@Pindar
Have you followed the advice given an rebooted your Sky box ?
My box says there's no signal when I change to that channel but works properly after waiting a few seconds.
This message was authored by: ASW821
Same problem here and only on CNN. It's currently showing 50% signal strength when it should normally be 80-90%.
Sometimes when I switch to CNN it says "Your Sky+ HD box isn't getting a satellite signal" and other times it works OK.
There was a technical change to the transponder which carries CNN HD yesterday but a reboot should resolve any problems.
In this case I would contact Sky if the problem persists and has been going on for a while, as an engineer visit may be required.
I've performed a reboot and the problem still persists. CNN signal strength is still about 50% instead of about 90% as it was before. How can I possibly have a fault if this problem is only on one channel and also bearing in mind the others with similar problems since yesterday?
This message was authored by: Paves
I’m having the same issue.  Whenever I change channel to CNN I get a ‘no satellite signal’ message for a few seconds and then I get the channel as normal.  I have turned off the power to the Sky box, and then back on again, but the issue still remains.  This only happens to CNN so far, as far as I know (I haven’t gone through every single channel that my box receives!).
This message was authored by: Philipdilip
Having the same problem keeps going blank then dispays no signal banner then comes back on
one thing i have noticed is the signal strengh is lower on that channel must eb a problem with sky
you tell em!! I have 2 recievers and it does it on both of them so how can it be a problem with sky recievers seems to me skys trying to get some moneys out of peeps by sending a enginear out when its got to be a fault with the cnn transponder
No point in rebooting your sky recievers folks its got to be a  problem at skys end after the technical change and then blaming it on customers sky recievers.
Locked
