Discussion topic: puck issue
This message was authored by: MichaelNewby
puck issue
Puck has constant white light and remote does nothing, changed batteries, turned on & off as instructed
This message was authored by: Jones_The_Cat
Re: puck issue
You've probably got a dead remote. They're trash - really, really not good. Try giving it a twist with a firm grip as if wringing out a cloth. This can sometimes spark them back into life, if only temporarily.
Also try turning the puck off at the wall for at least 10 minutes then power it back on. A full reboot can sometimes sort them out.
Re: puck issue
Hi @MichaelNewby
Further to @Jones_The_Cat tip about twisting the remote. If the remote is lighting up and has power, try repairing it via the instructions here: https://www.sky.com/help/articles/remote-control-help-sky-glass
It's it's completely dead you can get a replacement from Sky as the rent the puck to you. You will need to contact sky customer service as we are fellow subscribers here.
MikeAlanR
Re: puck issue
If none of these options work you can request a replacement remote via this link: https://www.sky.com/help/forms/streaming-tv-remote
If you have an old Sky Q remote, you can use that as an interim solution whilst you await the new remote.
Sky Stream, Sky Glass Air and former Sky Broadband customer
Avatar for MichaelNewby
Re: puck issue
Thanks guys, new one ordered, @Jones_The_Cat @MarkGoldsmith
Re: puck issue
Thx @mikealanr
