Discussion topic: White light on puck keeps flashing so I can get Tv when it does work I don’t get regular tv
Message posted on 09 Apr 2024 01:35 PM
Puck won't start most days just flashes white light and switching on and off does not make a difference. Resetting the wifi the same it's obviously defective and there is nowhere to report it the system just assumes it's on and you can go to settings It will not recognise "puck won't start" Why I don't know
it's very poor that Sky cannot check it all the testing is on the customer
Message posted on 09 Apr 2024 02:13 PM
Re: White light on puck keeps flashing so I can get Tv when it does work I don’t get regular tv
By definition Sky cannot remotely 'check' a device which isn't connected, and there's just no in-person support for Stream.
Message posted on 09 Apr 2024 02:47 PM
Thanks for that
How do I go about getting it replaced
it's clearly defective
I saw someone say they can go wrong after a firmware update Cheers
my nearest shop is Bury
Can they handle it
Message posted on 09 Apr 2024 03:26 PM
Have you tried the recovery procedure as described in step 4 in this Sky help article here;
At the end of the help article, click on get in touch button to get further help contacts.
