219
This discussion topic has been answered Discussion topic: Watch from start fast forward issue once broadcast has ended
This message was authored by: Gijimes333
Re: Watch from start fast forward issue once broadcast has ended
This is certainly an issue and I am shocked that they are saying it is not. I will call and log too.
This message was authored by: TFDERRY
This is the only acknowledgement of the issue in this thread.
18 Oct 2024 11:45 AM
Posted by a Sky employee
Hi all,
I wanted to let you know we are investigating an issue with Watch from Start where on occasions using fast forward or rewind on programs it jumps back to Live TV.
I'm really sorry this is happening but we have the right teams working to get this resolved as soon as possible.
Workaround: Instead you can search for the programme (using voice or the menus) and then restart the programme this way.
Chloe-W22
Community Manager
This message was authored by: Stottie
100% Sky are aware of the issue. Others have received a rebate for the issue. Sky are lying to you, or the agents you spoke to are completely useless.
I've seen this issue on my 3 pucks.
This message was authored by: MFoord
They are aware, just not prioritising. Best thing people can do is to walk away from Sky, that is the only way they will notice. You can always re-sign up as a new customer once they eventually sort. I've been with them over 20 years and still paying the same as a new customer! I was told best by Sky advisor to re-connect wired rather than rely on WiFi - ridiculous! Sky Glass TV can be used without sky subscription so don't be afraid. Theres no benefit of loyalty now a days and disappointingly there is nothing unique about Sky anymore.
This message was authored by: Chloe-W22
Morning all,
Thanks again for your contribution to this thread, and for your patience. With support from this discussion thread, our Support Teams have been investigating the issue with Watch from Start reverting to the live channel and believe they have built a fix that we expect to be included in the next software release. The release date is tbc but will likely be nearer the end of January.
I'm really sorry for the inconvenience this may have caused,
Chloe-W22
Sky Community Manager
Have a story you want to share with us? Send your Thanks to Sky here
This is not an acceptable response. Why have your customer services lied about this issue which caused quite a few Glass subscribers to leave after 20yrs.
2 extremely heavy Monitors and 2 Firestick NO SKY and no regrets
This message was authored by: Nellyall
Stream jumping back to start on fast forward
I've just received my Sky Stream as a new customer. I've not currently paid for Ad Skipping. 1st attempt at using 'Watch from the Start', as expected can't fast forward through the ads at the beginning, no problem.
However I then wanted to fast forward a bit through the program itself as we had seen a bit of it already, but as soon as I try to fast forward the show, not the adverts, it jumps straight back to the start of the program & we have to watch the adverts again and then are not able to fast forward the show again to get back to where we were.
Is this expected?! I may be cancelling within my 14d cooling off period if so!
This message was authored by: Ellie_TV
Re: Stream jumping back to start on fast forward
I'm afraid that the 'watch from the start' function isn't hugely reliable when it comes to fast forwarding through a show.
I personally have stopped using it due to suffering the same infuriating issues as you. I now wait for the programme to appear on demand before watching.
ah ok thanks. So you dont get the same experience with on-demand only with watch from the start? I'll go & have a bit of a test!
This message was authored by: Stephen+Mourton
@Ellie_TV   You say "I personally have stopped using it due to suffering the same infuriating issues as you. I now wait for the programme to appear on demand before watching". Do you mean the Playlist?
The quickest temporary solution I have found for this is to then use the voice function of the remote control asking for the programme in question and then restarting, forwarding to where you left off. Not ideal but a work around for now .....
This message was authored by: whoamIwhoareyou
Hi,
Unfortunately,  the work around suggested does not work for me.
The program i was watching is no longer in my my playlist (somehow this bug removes it) and, as it is no longer live so I can't restart it.
Happened 2 weeks running on my program.
Very disappointing.
Hope the deletion from playlist issue is fixed as part of this too.
This message was authored by: AJH
I have been experiencing this problem for some time and, today I finally posted on it.
@Fothergill1 pointed me to this thread (thank you) and I see that I am not alone 😀
I hope this will be resolved soon (expected late January as I understand it) as this is a Huge irritatation..
Regards
Tony
@AJH  Your welcome.  It hapened to me at lunchtime when I forgot I had paused the programme and then went to FF.  It has just happened again about 20 minutes ago but on this occasion I did a watch from start and as soon as the programme finished in realtime it jumped to the end without even being fast forwarded 😫 🤬
It's a terrible waste of time and money to be offered a product, the subscription, that doesn't do what its supposed to do.
I cancelled my sky after 20 years because of this issue.  I'm pleased to say that the Glass tv is working fine with no Sky subscription. A lot of apps are still available, also has freeview channels and my firestick provides everything else I need. UHD and Atmos Sound are still there.  One thing I do miss is Add skipping but I'm sure I will get over that.
  • I feel that compensation is something Sky should have offered during this issue. They have not solved the Lipsync issue yet (The words and mouth movement are not in sync) and that has been 3 yrs since this started. Can't see a fix coming for either of these issues soon as Sky have given no updates.
Answered - Go to Answer
