Discussion topic: Sky stream problem
Message posted on 12 Jul 2024 07:24 AM
Sky stream problem
Hi as i was having problems with my skyQ i had to change to sky stream . I am not really that impressed with it . At the moment i am having to turn it off and back on at least once a day , as it comes up with this is embarrassing theres a problem . It happens alot on channel 4 E4 . Is anyone else getting this problem
Message posted on 12 Jul 2024 08:16 AM
Re: Sky stream problem
If using the apps make sure you are exiting them properly as this may help. Don't just press the home button to exit them, when in an app keep pressing the back button until it either exits back to the Sky Home Screen or it brings up a prompt asking if you want to exit.
Also open Netflix go to get help and then check your network and this will tell you the download speed the device is getting. This could also potentially be the issue.
Message posted on 12 Jul 2024 08:27 AM
Thank you will try that but it mostly happens on channel 4 E4 not on the apps .
