Discussion topic: Sky stream , honest review
Message posted on 04 Mar 2025 04:20 PM
Re: Sky stream , honest review
Yeah I get ya. What I mean by holding off, they said I have 60 days to return sky q back to them. So I'll give it until then so I know I am fully happy to stay with sky stream
Message posted on 04 Mar 2025 04:27 PM
yes thats a good idea.
Message posted on 04 Mar 2025 05:43 PM - last edited: 04 Mar 2025 05:45 PM
Note that the 'cooling off' period for Stream is only half that length of time.
Message posted on 04 Mar 2025 05:45 PM
HAd stream for nearly a year - terrible product.
I have a stable connection - but the puck keeps disconnecting from the the internet - cable or wifi - makes no odds
Now it is happening everyday. 3 hours with ISP to ensure nothing wrong with interent - puck the only device with issues - sometimes might get 20 mins before losing contact - technical fault my a**e.
Had 3 pucks, now need to dig out the phone number, if anyone on here has it, would welcome you to post it. Phones rarely last less then an hour..
Wish I had just had a dish put up bit thoiught ,no, go with the flow. Bad mistake.
Message posted on 04 Mar 2025 05:48 PM
You can find the number to call, via the 'need more help' link towards the bottom of the page here: https://www.sky.com/help/home
Message posted on 04 Mar 2025 06:20 PM
@pressandgo wrote:HAd stream for nearly a year - terrible product.
Out of interest which ISP are you with ?
Message posted on 04 Mar 2025 06:28 PM
Talktalk, currently checking out that my connection and router are fine - could not find any issues - Neflix via tv app is gettting 55Mbps
a smart phone via wifi 62,
Puck is the only device that fails - just had it working, out of room for 10 mins - back to a blue screen, cable or wifi makes no odds.
Message posted on 04 Mar 2025 06:30 PM
Used that link - just a dead end - says for stream but one link is about satellite!!
Message posted on 04 Mar 2025 06:35 PM
@pressandgo wrote:Talktalk, currently checking out that my connection and router are fine - could not find any issues - Neflix via tv app is gettting 55Mbps
And when you use a Ethernet cable you are turning off the WiFi in the settings then rebooting the puck ?
Message posted on 04 Mar 2025 07:20 PM
Off to try and get it working again.
Message posted on 04 Mar 2025 07:22 PM
No, guess I should but not sure what you mean by re boot
Message posted on 04 Mar 2025 08:20 PM
@pressandgo wrote:No, guess I should but not sure what you mean by re boot
If the WiFi is enabled the device will prioritise that over the Ethernet connection which may explain why you haven't seen a difference.
I know from experience that even when you turn the WiFi off in the settings it typically keeps using it until a reboot is performed. You can perform a reboot via the settings
1. Go to Settings
2. Go to System Management
3. Press Select
4. Go to Resets and Updates
5. Press Select
6. Go to Restart Device
7. Press Select.
Note this will take a few minutes to reboot, so expect to see a blank screen for 2 minutes until the Sky logo appears as its starting up.
Or alternatively turn it off at the plug for several minutes.
Message posted on 05 Mar 2025 06:22 PM
Tried that, twice, worked for about 15 minutes then went off again. Very frustrated now.
Message posted on 06 Mar 2025 07:51 PM
I'm having exactly the same issues. I regret the day I decided to go with sky stream. I can't wait for September when the contract runs out, I won't be going with stream again.
Thought this was all down to sky's broadband as the signal wasn't brill, so switched to virgin media fibre and the I turned signal is brilliant but we still have trouble with sky stream on sky glass.
Message posted on 06 Mar 2025 08:09 PM
I've had sky stream now for just over a month....i do think some of the problems are to do with which ISP you are with.....I'm using a 5g router....when I got sky stream I was with giffgaff (02 network)...and had nothing but problems...but after a week switched to smarty (3 network) and not had any problems at all...overall I'm very happy with how sky stream works.
