Discussion topic: Sky stream background images
04 Aug 2024 03:10 PM
So, we've been using the Sky stream for about a month after leaving BT.
Although in principle it's very good there are some irritating issues which might force us to leave.
- 1- the background images/adverts for programmes to watch mean the tv guide is really hard to read in places. White background, white wording, equal can't read it.
- 2- Lip syncing when watching tvseems to be an issue
- Not easy to fast forward through the guide to a future day to add it to the schedule (or rewind)
- Not able to easily go back to the beginning of a programme to watch from the beginning
- Overall it's OK, but, in comparison, the BT tv hub is 100 times more user friendly
04 Aug 2024 04:50 PM - last edited: 04 Aug 2024 04:51 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Diane631
1 - you can put your puck in high contrast mode in settings > Accessibility > High contrast
2. There is an issue which should be fixed in a software release. It might be that your puck has got this yet. In the meantime time go settings > picture and sound > sound and change the digital audio output to PCM.
3. Press and hold the right hand of the center button when in TV guide and days of the week will be displayed, navigate left and right and press select to go to that day of the week. Note you cannot go back in time like you can with BT/EE TV.
4. If it's a live broadcast click watch from start. You can then use voice commands go forward / back x minutes. Go to X minutes etc.
The videos here are useful for helping get used to it, particularly the playlist section.
https://www.sky.com/help/articles/sky-stream-faqs
Hope this helps
MikeAlanR
55" Gen 2 Sky Glass atlantic blue, 65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Sky SoundBox. Former Sky Q, Sky+ HD and Sky+ customer.
