Discussion topic: Sky Stream pic pixelating and freezing.
This message was authored by: st1ngray1
Re: Sky Stream pic pixelating and freezing.
So what is the solution
This message was authored by: Sr19
If you read all the messages, this is more a page to vent. Sky have offered no solution and don't appear to acknowledge the issue.
This message was authored by: Alan178
I had really bad pixilalation when streaming. First Apple, then Prime and occasionally Netflix. Got to the point is was not worth watching. I found you can turn on a judder in the sky visual settings menu. It has only bloody worked! Hope this helps guys.
Thanks very much for the suggestion - I have tried this and so far so good. Thanks again, my kids will be delighted!
This message was authored by: AndyW31
I am showing as 33mbps on Netflix. Losing 100mps between the router and the puck. My puck is pluged into the ethernet to. Any ideas on how to speed it up?
This message was authored by: KevDon
I've only recently had sky and fibre installed after leaving virgin. My sky puck is connected directly to my sky hub via ethernet. I've been pretty shocked how often the picture quality suffers with macroblocking/pixelating. We just finished watching that new "Dear Santa" movie and it often looked terrible. The scene where the boy is walking through the park with Jack Black, Jack's outfit is a shimmering mess. Please everyone take a look at that scene around 30m30s and have a look if his outfit is pixelating.
This message was authored by: HavencroftKev
Pixelation on all channels, it's unwatchable!!
Hi Community,
So it's a week today since I've been a Sky customer with Sky Stream.
Up till now I've been really pleased, however today I am experiencing really bad pixelation across all channels on Sky Stream.
I'd say it's so bad it has become unwatchable.
Any advice would be very much appreciated.
This message was authored by: Ellie_TV
Re: Pixelation on all channels, it's unwatchable!!
@HavencroftKev wrote:
Hi Community,
First of all, check your network connection. If you're connected to your broadband via WiFi run a network check using the Netflix app. Open the Netflix app and go to the get help section. Run a network check there and see what speed is being received by the puck. You need a minimum of 25Mbps for HD and 30Mbps for UHD.
A regular reboot of your puck is often useful for flushing out cache gremlins which can slow things down.
Also a reboot of your router can sometimes help too.
Would first suggest trying a restart of your Sky Stream box
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete.
Recommended minimum broadband speed of 25Mbps. Or 30Mbps if you add an extra Sky Stream puck or to watch in UHD.
As mentioned above, a good way to test, doing a few netflix app speed test on your pucks over say a fifteen minute period.
Launch Netflix on your pucks (you do not need to be logged into it, if you do not use netflix) and scroll down the left menu to Get help.
Choose Check Network.
Thanks for your reply, I'm really pleased to report that resetting the Stream Puck appears to have done the trick.
This message was authored by: JustTryingToHelp
Thanks.  Tried this as soon as you posted it.  Have not noticed any problems since!  Early days yet, but hopeful.
This message was authored by: DeliveryMan
I've had Sky Stream for around six months now and have recently started to notice pixelating mainly on the sky channels. It's getting annoying so I did a Google search and it brought me here.
A reboot fixes it for a few days but then it will return. This issue is either the cheap puck or sky's servers.
I have 1gb broadband which is fine and I've tried the puck hardwired and over WiFi.
This message was authored by: leigian
Pixelating and sound out of sync on live tv channels happens with my sky stream on a daily basis and always after switching from on demand content to live tv.
To solve the problem I go to settings and restart the box , this solves the problem temporarily until the next time I use on demand.
This message was authored by: QPRROCKY
I'm with you!! Mine will be fine for a for a while but then it starts again - pixelating, getting the 'there is a technical fault with this programme'..... sick of it. It is os glitchy and I rue the day I ever switched for Q as that was excellent for me. I have 500mps broadband and ALL the apps when viewed through my Sony Smart TV are absolutely perfect and never have any issues. It is 100% Sky servers - they are rubbish.
I will be contacting them after Christmas and if I don't get any joy I will be binning Sky for I am definitely not getting what I paid for.
This message was authored by: Shelley661
Ours is the same, starting to regret moving from Virgin back to sky.
since we have had these puks had nothing but issues.  Already had one puk replaced.
the main one in the living room is freezing, sound continues but picture stops for a few seconds.
have reset this sodding puk more times you can shake a stick.
if puks are the way sky is going they need to do some serious work behind  the scenes to get these working without the constant glitches.
Once this term is up will seriously look at other tv providers if these continue to glitch.
