Discussion topic: Sky puck - constant picture problems
Message posted on 02 May 2026 08:58 PM
I have constant picture problems since upgrading to the sky puck from Sky Q.
waiting for programme to load / fizzy pictures and constant freezing spoils watching tv
I've reset broadband router/puck numerous times but problem persists
Message posted on 03 May 2026 07:18 AM
Re: Sky puck - constant picture problems
@Ed2toe Hi. There are usually two common reasons for this problem. The first is your internet speed. Go to Netflix (no need to be a subscriber) and in their help settings there is an internet speed checker. Ideally your Mbps should be over 25 for HD, 30-35 for UHD.
Secondly the puck is very sensitive, so ensure it is standing on a shelf away from any objects with about 6 inches of space around it and nothing on top of it.
These are two easy things to check and often resolve the problem.
