02 Jan 2025 09:12 PM
Same here.
Over Christmas strugled to watch hardly any live TV.
Our solution is to switch to "watch from start" and then watch on "catch up"
Seems to work
03 Jan 2025 07:15 AM
Has anybody had the box flicker between a black screen and the main page. I have started getting that and have to turn off and back on to get main screen.
03 Jan 2025 01:38 PM
We have watching on catch up as that appears to work.
trying to watch the darts last night was a mare, constantly out of sync and juddering.
have reset, juddering switched kn, which is suppose to work, but doesn't appear so when it's live television.
01 Feb 2025 07:07 PM
Only Had Sky Stream for a week and this seems to be an issue. I have 150Mps Broadband, hardwired the puck to the internet and still get the issue., sometime just goes completely blank. Watching the same feed on sky go via an iPad on WiFi with no issue. Sky stream puck is probably the issue I guess. I have swapped all cables and used different HDMI ports on my TV (That previously worked error free)
01 Feb 2025 07:10 PM
Yeah it's definitely buggy, mine will work fine for days or more then all of a sudden its a pixelated mess and has to be reset. It's fine then so definitely the puck.
02 Feb 2025 08:58 PM
Hi, have been struggling with the pixelation and freezing all day. Tried different connection methods WiFi & Ethernet. Have tried restarting and resetting the device. I then felt the pick and discovered it was quite warm. Unplugged it for a few minutes to allow it to cool down before turning it back on. This far all the issues have been fixed 👍
This (on my device) appears to be a simple overheating issue 🤷♂️ Hopefully this is helpful for others 🤞
03 Feb 2025 10:38 PM
Watching "From" on sky max tonight. Had to reboot the puck twice because of pixelation
04 Feb 2025 06:16 AM
We have had this and told sky several times they deny its happening before Christmas we had the internet checked out as sky deny its happening. When it carried on happening after this they sent a new puck out exchange at door. We did that and it can still happen on new puck. We told sky look at your forum its not just us. Sky don't seem to look at this as their claim is everything is fine at our end,it's got to be yours. Yes when it happens it requires restart of puck. Sky won't do anything as they believe its not happening. The problem occurred from the middle of October up till then everything had been fine. Sky do not monitor this forum
10 Feb 2025 09:52 PM
Have bt fibre 900 meg and just installed the pucks skys freezing randomly and picture quality is pixalating surely this aint right
11 Feb 2025 08:31 AM
Yes and I have to turn it off and back on again to clear it. We also had an issue trying to watch a recording of seal team season 6 last night. It started then froze with the waiting to load message. It's hardwired and internet was working great. I think something on the pucks internal circuitry is failing and that's why we're all having so many different issues.
11 Feb 2025 02:08 PM
Since lthe PUK has been changed it still Pixelates on live TV mainly, annoying when trying to watch the rugby or football or darts !!
sync issues still happens but not as frequent as it did on the previous PUK.
Never had issues with pixelating or sync issues when I had a box, which would suggest it's an issue with how the puks have been designed to stream from the base router.
not sure how sky can say it's not a PUK issues with so many people having the same issue 🤷♀️
11 Feb 2025 03:24 PM
It's a Puck.
The fact that your replacement Puck behaves in much the same way as the original suggests the problem lies elsewhere. Mine, over wifi using a standard ISP provided router has no problem with pixelation, freezing or poor synch.
11 Feb 2025 08:00 PM
Sorry didnt realise was being spell checked!!
something must be going on as so many people are having the same issue.
11 Feb 2025 08:11 PM
I'm convinced it's the Puck. It feels cheap and its just not up to the job
11 Feb 2025 10:16 PM
Definitely the puck, mine will work fine for days then all of a sudden its a mess. A speed test shows my WiFi is fast and stable. Plus of course it'll work perfectly fine after a reboot....for a while. If it was maybe a blip in my WiFi surely the puck would sort itself out if left long enough but it doesn't, only a reboot will sort.
