22 Jun 2023 02:47 PM
Currently you can't find Marvel's Secret Invasion on Sky Stream, so you can't add it to the playlist. It does exist on Disney+'s menus, so it's watchable, but it's not connected in the way Sky Stream is meant to.
23 Jun 2023 12:03 AM
Posted by a Superuser, not a Sky employee. Find out moreDrop the viewer relations team an email on
viewerR@sky.uk
Hopefully they can investigate and resolve
22 Jun 2023 02:53 PM
@A+JW wrote:Currently you can't find Marvel's Secret Invasion on Sky Stream, so you can't add it to the playlist. It does exist on Disney+'s menus, so it's watchable, but it's not connected in the way Sky Stream is meant to.
Unfortunately there are quite a lot of things which don't integrate well with the playlist on Sky Stream. It's still all a bit hit and miss. It'll hopefully get better in the future.
viewerR@sky.uk
23 Jun 2023 11:11 AM
Posted by a Superuser, not a Sky employee. Find out more@A+JW I have a total of 17 programmes that I watch through Disney + which Sky either cannot find or does not have all the series / episodes.
This is hardly what Sky advertise when they claim programmes are integrated to the Apps 😡
24 Jun 2023 11:02 AM
Sky replied, basically acknowledging what they imply in their advertising doesn't work on Disney+ which isn't exactly acceptable.
I'm sorry that you have not been able to use voice or search to add this to your Playlist.
Unfortunately it is not possible, in most cases, to add Disney+ content to your streaming Playlist.
Whilst, currently the search/Voice feature do not find this programme, it is easily found on the Disney + app itself, being as it is, a brand new show.
24 Jun 2023 12:07 PM - last edited: 24 Jun 2023 01:00 PM
Secret Invasion is listed if you click search with remote (Click the ... on the remote and then enter Secrect Invasion) on Sky Glass or Sky Stream and you can add to playlist
Also is listed on Sky menu home screen
24 Jun 2023 01:37 PM
Posted by a Superuser, not a Sky employee. Find out more@Paul+Boland Unfortunately not on my Glass TV. I got nothing with a voice search or with typing it in. Weird, I have no idea why this should be the case when you can find it as evidenced by your photo. I'm not going to lose sleep over it though.
