Discussion topic: Lip Sync issues - Sky Stream
Message posted on 24 Nov 2024 04:17 PM
@BubbyGee wrote:I'd been battling this problem for weeks. Watching BBC1 and synch was badly out. I tried going to the tv guide, choosing another programme then went back to the guide and selected BBC1 agin. It worked...perfect synch.
this makes it sound like you haven't changed channel from BBC 1 for weeks 😆
sorry it just made me laugh.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck; Build: QS037.058.00P; UI Version: 3.204.1 | Sky Broadband Superfast
Message posted on 24 Nov 2024 04:24 PM
When you watch Live TV it pause of a 5 seconds and than plays again, it acting like the buffering has caurt up with the video, is this the probem, it only happens on Live TV, I have to press the play buttion to pause it or ff it so it stops doing it.
I am not a Sky Engineer but at one time wanted to be one or a BT Engineer... 🙂
I like working things out like its a puzzle... 🙂
I was a PC Engineer and fix peoples PCs by going to there house, Windows XP was known to slow down PCs over time and clog up the PCs RAM and its start-up and had to reinstall it for the customer.
Sky Glass Air 55 inch.
Message posted on 24 Nov 2024 04:28 PM
Seems that it doesn't matter whether it's live or not. It's a well known Sky Stream problem but despite many promises they haven't sorted it yet, relying on customers to fiddle with tv settings. Very unsatisfactory. This works for me but I shouldn't have to do it.
Message posted on 24 Nov 2024 04:31 PM
@Rich5707 wrote:See people still have an issue with this is unreal. But last week I solved the issue I'm having with the lip sync issues
How I got it to work.
I have a Samsung Q series TV with the Samsung Q60 sound bar which both devices support ARC and eARC which both support dolby atoms sound, but I didn't set mine up this way.... Turned out I made the mistake and set mine up with optical wire which doesn't support dolby atmos (or dolby sound) , as soon as I used a HDMI 2.1 wire and connected them both into the correct HDMI eARC sockets on both sound bar and TV my lip sync issues have now gone.
I have waited a week. Watched multiple UHD shows on both sky sports and TNT sports (also standard shows which don't use dolby) and the issue is fully gone. The other issue is if your TV doesn't support dolby atmos but states dolby sound it still won't work. We have another Samsung TV slightly older but states dolby sound and not atmos and the issue with lip syncing still occurs.
During my dealings with sky to get this issue solved no one has stated optical wire doesn't work or TV has to be dolby atmos, in which I was told dolby sound was required.
I hope this helps others, for me it was a simple wire change.
Optical digital to soundbar only ever really works without lip sync issues if your going direct from the device outputting the audio. In this case that's the Sky Stream Puck not the TV it's connected to. Introducing the TV as the mediator between the Puck and the soundbar is what introduces the delay. Of course the big issue your quite rightly thinking is the fact that the Puck doesn't have an optical out (unlike some older Sky+ boxes). The advice though that I always give people with soundbars particularly is to connect the devices (sky, blu-ray etc) directly to the soundbar and not via the TV. Which again has become an issue as so many soundbars now seem to only have 1 hdmi input. That's when I plug a decent quality hdmi switch in to that 1 input and plug the devices in to the switch. A faff but still you're get better sync this way.
Message posted on 24 Nov 2024 04:57 PM
I made a error in my message, I mean...
When you watch live TV it pause for 5 seconds and then plays again the sound is still playing, its like its buffering the liveTV feed and running out where the buffer has catching up with LiveTV make it shudder.
Message posted on 25 Nov 2024 05:14 PM
Re: Sky tv sound - constantly out of sync
Hi I have a new sono arc soundbar and Sky q and I am getting terrible lip sync on sky q only. Everything else and aps are good. I have tried many of the audio settings but nothing seems to help. Can anyone help plz ?
Message posted on 26 Nov 2024 08:13 AM
Unfortunately this doesn't work, I don't use optical and the is only one socket out of the puck so this has to go straight to the TV and then I have eArc hdmi to the soundbar I have tried all the various sound settings and nothing works I have to reboot everything at least twice a day for a temporary fix. I have only been a few weeks with Sky, I never had these issues with Virgin and I wasn't aware of the issues until I moved....... I wish I hadn't now and I am stuck in a contract. I would reiterate I don't have these issues these issues with my Amazon streaming fire sticks, I am amazed that Sky don't follow this community and respond the number of people complaining of the same issue is not acceptable
Message posted on 26 Nov 2024 08:23 AM
Re: Lip Sync problems with Sky Stream
I have tried all different sound settings, at the moment I have the puck and TV set to stereo, unfortunately nothing seems to work. I don't have any sound issues with my Amazon fire sticks
Message posted on 26 Nov 2024 11:47 AM
I've ended up cancelling and returning my sky stream, as have many others, due to this problem. Their reluctency to fix and address this issue is horrendous.
Message posted on 26 Nov 2024 01:50 PM
@BC1956 If you just have the $ky puck then you'll be in a rolling contract which you can opt out of by giving a 31 day notice. Unlike other streaming services when you can cancell immediately sneaky $ky pick your pockets for another months payment. You can still cancel even in contract if $ky is failing to fulfill their side of the contract by giving you a watchable and listenable product, which it obviously is not.
If you telephone $ky to complain they will just blame the problem on your TV or soundbar as they did with me.
Message posted on 26 Nov 2024 03:06 PM
@BC1956 wrote:Unfortunately this doesn't work, I don't use optical and the is only one socket out of the puck so this has to go straight to the TV and then I have eArc hdmi to the soundbar I have tried all the various sound settings and nothing works I have to reboot everything at least twice a day for a temporary fix. I have only been a few weeks with Sky, I never had these issues with Virgin and I wasn't aware of the issues until I moved....... I wish I hadn't now and I am stuck in a contract. I would reiterate I don't have these issues these issues with my Amazon streaming fire sticks, I am amazed that Sky don't follow this community and respond the number of people complaining of the same issue is not acceptable
What make and model number is your soundbar?
Message posted on 26 Nov 2024 05:32 PM
Panasonic SC-HTB688EBK
Message posted on 26 Nov 2024 05:34 PM
Thank you I will check my Docs and if it's rolling I will be out
Message posted on 26 Nov 2024 05:37 PM - last edited: 26 Nov 2024 06:01 PM
@BC1956 wrote:Panasonic SC-HTB688EBK
You have an HDMI input on that Soundbar. Try plugging the Sky pucks hdmi cable in to the soundbar rather than in to the TV. Then select HDMI input on the soundbar and see if the audio sync is now better matched to the picture. The soundbar HDMI output will send the picture to the TV.
EDIT: Sorry my mistake, this soundbar doesn't have an HDMI input as I thought. Just the HDMI ARC Out to TV.
Message posted on 26 Nov 2024 05:43 PM
Hi thank you for your quick response. Unfortunately the soundbar only has 1 hdmi socket, there is an in but no out
