8
This discussion topic has been answered Discussion topic: Where is the OK button on Sky Q remote
This message was authored by: DS3
When our TV / SKY has been on virtually all day a message saying that the box will turn off automatically.
it tells you to press the OK button to dismiss this
where is the OK button please?
This message was authored by: nigea99 Answer
Re: Where is the OK button on Sky Q remote
Hi @DS3
Are you sure that this is not a message from your TV set?
If it is you need to use your TV remote not the Sky Q remote.
Or possibly just the volume keys using the SKY Q remote which is what I do when my TV has a similar message (including "Press OK to continue")
(I suspect this message is from the TV as  you often have less interaction with the TV than a SKY Q box and TVs also usually have a shorter time before shutdown than a Q box)
@DS3
Centre dot in middle of up, down, left, right buttons.
Avatar for DS3
Hi Daniel
the centre button does not clear the message
@DS3
That's what can be described as the okay button… try the dismiss button.
@DS3  Use the button with a square and arrow pointing right. (It's the one highlighted with a yellow box on the image below
Hi @DS3
Hi @DS3
This message was authored by: Hardingham
Screen says New Software change list   Press O k where is this button on Sky Q remote please
hi @Hardingham
This message is from your TV & not SKY
You will need to use the TVs own remote for this
