Discussion topic: sky mini box
This message was authored by: Graham83
sky mini box
MY Sky mini box doesnt seem to connect during the night its ok until switchd off about 11 pm
and ok after 7am in morning but during night will not connect to main box are there any time
settings anywhere
Re: sky mini box
@Graham83  You say it's switched off at around 11pm nightly, is this in standby mode or at the plug
if the latter that is the reason it won't connect
edit see if this article helps
https://www.sky.com/help/articles/using-the-standby-settings
Avatar for Graham83
Re: sky mini box
it is only switches into standby mode as per nomal it is not unpluued at the mains box in other bedroom is fine
Re: sky mini box
@Graham83 Are both boxes set to the same standby setting see the link posted above
