Discussion topic: SkyQ and Prime Video Issue's
Message posted on 01 Sep 2025 09:19 AM
Re: SkyQ and Prime Video Issue's
As I posted it's ok on my box, (so far!) so I wonder if the issue is linked to a Sky Q box version?
For reference mine is 32B108 and software ver Q320.000.15.00L
Message posted on 01 Sep 2025 11:29 AM
I will have a look and post the version. I made my box do an update so I am presuming it is the latest update...but it is still not working. Checked this morning and did another switch off just in case and nope... ! I have to hunt for what I want in the search box and then find it manually. It is frustrating!!
Message posted on 01 Sep 2025 12:19 PM
this is my version.
Message posted on 01 Sep 2025 01:00 PM
My sky's went on Tuesday as well
Message posted on 01 Sep 2025 01:30 PM
Well it's different to mine (I think yours is a newer version than mine wihich has HDR for the iPlayer) so the hypothesis is possible.
We now need to see if others that have suffered the same issue have the same version as you.
Message posted on 01 Sep 2025 02:06 PM
Mine is exactly the same as yours, tried all the fixes and nothing worked. Mini box working fine but main Q tv unusable.
Message posted on 01 Sep 2025 02:11 PM
Amazon Prime Video app - programme list has reduced significantly
When i open the app, the list of availbale/recommended/previously watched programmes has reduced significantly and i have to search for any programmes i want. If i access via my Smart TV it's fine but not when via SkyQ?
Message posted on 01 Sep 2025 02:37 PM
@RussLcy wrote:Mine is exactly the same as yours, tried all the fixes and nothing worked. Mini box working fine but main Q tv unusable.
Box version?
Message posted on 01 Sep 2025 02:42 PM
Yes, my Sky Q box version, with my main Samsung TV only shows 2 lines of available viewings, as described by OP. Mini box in bedroom is working as normal
Message posted on 01 Sep 2025 02:43 PM
@RussLcy wrote:Yes, my Sky Q box version, with my main Samsung TV only shows 2 lines of available viewings, as described by OP. Mini box in bedroom is working as normal
Which version of the Q box is it?
Message posted on 01 Sep 2025 02:46 PM
Software vQ320.000.15.00L
hardware 32B206
Message posted on 01 Sep 2025 02:49 PM
@RussLcy wrote:Software vQ320.000.15.00L
hardware 32B206
Same as Bubbles
but I think mine is the same and does not have the issue, I'll check tonight.
Message posted on 01 Sep 2025 02:57 PM
Can all those with the issue, please contact Sky to report it? The more of us who do will mean they have to at least look at it quicker and post some kind of note on their help forums to say they have an issue.
Thanks all. I am glad it isn't just me.
Message posted on 01 Sep 2025 02:59 PM
Can this be done via chat? I can't stand ringing sky!
Message posted on 01 Sep 2025 03:00 PM
Probably... I know the feeling!!
