Discussion topic: Sky q switches off - 15/05
Message posted on 16 May 2025 03:30 PM
Re: Sky crashes
I experienced the crashes too.
Message posted on 16 May 2025 03:31 PM
Frustrated
The Q Box switched off at 22.00hrs last evening. Came back for a short while. Today despite one hour of checking and double-checking I still have a Q Box with a yellow light and zero response when I use the TV remote.
Unbelieveable for me and many other Sky clients
Message posted on 16 May 2025 03:34 PM
SKY Q NOT WORKING
Hello,
last night my sky q just switched off and also in my conservatory Q box there.
not working,
I have done as recommended to unplug and leave for a few minutes then plug back in to reset but fault still there.
i have also gone into settings and changed to Eco or active as suggested but still not working.
it is saying Sky Q box not connected to WiFi but my WiFi is working fine.
so I need to try something else or send an engineer out to fix this please.
Re: Sky crashes
we did as well.. all seems fine today..
Message posted on 16 May 2025 03:37 PM
Re: SKY Q NOT WORKING
Please see the post marked as the answer on the large thread relating to this outage.
Message posted on 16 May 2025 03:38 PM
No Sky in Ribble Valley
Hi,
Is Sky still down in the Ribble Valley Lancashire. Whalley to be precise. Thanks
Message posted on 16 May 2025 03:39 PM
If you are still having trouble accessing your Sky Q services and haven’t restarted your box since midnight on 16 May, switch off the box at the power socket for 30 seconds and back on again to restore service.
Also reboot your main Sky Q box if you're having trouble accessing a mini box.
Read the Sky answered post here
Message posted on 16 May 2025 03:40 PM
Re: No Sky in Ribble Valley
Re: Frustrated
Message posted on 16 May 2025 03:41 PM
Re: Sky Q box freezes up and screen goes black every 20mins
@Broseley89 wrote:
While we are trying to watch a recording, the Sky Q box freezes up and the TV screen goes black. Unplugging the box for 10 secs resets it but 20 mins later it does it again. If we're also recording something it stops recording. It's driving us mad! Just having the TV on is OK.
Message posted on 16 May 2025 03:42 PM
Sky Q not sending signal to tv
Hi
Sky Q box problems..... if I unplug at the mains then plug in again it works - no satellite signal strength problems and picture on TV all fine. After ten minutes I lose the picture and get the "no signal" message appearing on the TV. I've updated the software on the Sky Q box, swooped HDMI cables and HDMI ports on the TV and still get the same problem.
Advice and help please!
Re: Sky crashes
Sky Tv not working
Re: No connectivity on Sky Q
@Malcolm1949 wrote:
Since 905 pm last night no satellite connection , tried switching on and off at mains, and waiting , helpline hopeless .Now been off for 17 hours , have requested a call back but no acknowledgement from Sky . What else can you do especially as no one at Sky is responding?? Do they actually have any engineers? I have tried online and telephone helplines , various non responses or 'we are having technical problems'
Message posted on 16 May 2025 03:44 PM
Same here. Couldn't even get through. Tried to call today as well but got message saying lines are busy and got cut off. We should have compensation.
Message posted on 16 May 2025 03:45 PM
Re: Sky Q not sending signal to tv
@Andrewh2 wrote:
Hi
