1750
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky q switches off - 15/05
Locked
This message was authored by: Damien1975
Re: Sky q switches off - 15/05
I would agree, but this failure occured at exactly the same time as the issue last night?
Re: Q for quizzical ?
@PeterRock wrote:
My Sky Q box went in to stand by 3 times last night,  but Sky Go on my Chromebook still worked. This is the second time this has happened this year.  When I tried to look on the Sky web site, it wouldn't let me sign in.  I've had Q for 8 months now  and sometimes wish I'd stuck with the hd+ box.
hi @PeterRock
As you will see from the mega discussion that I have moved your post to, last night's problems were much wider than your box.
In my eight years with SKY Q this is the 1st time I have seen such a  failure across many (if not most) Q boxes.
I know that Q does not suit many who were  used to their old trusty HD boxes (although these are now failing more regularly due to their age)
This message was authored by: Bill1968
@Damien1975
Younsaid you replaced the batteries. Have you checked they're in the right way?
This message was authored by: sharlily
Last night
Are we being compensated for last nights fiasco??
No it doesn't. Pressing any of the buttons on the remote control does nothing
Re: Arghhh
@MamaBD
Do you have Sky+ (where you've posted)? There was a large outage last night mainly affecting Sky Q.
Hi @Damien1975   Okay, then follow the link I provided and it will take you to a free remote replacement request form.
Yes. I've probably placed the batteries in and out about a dozen times
This message was authored by: Charlie19771
Re: My sky box keeps cutting out to a black screen. Its only temporary (a second or less)
same here
Sky Q error?
Last night (15 May) during the Eurovision, my Sky Q box "failed". It was still showing the green power light and the recording red light, but the TV output (HDMI) was showing nothing, and my TV was saying No Signal as it seemingly wasn't getting anything from the Sky Q box. I had to turn it off by the mains and wait a few minutes before plugging it back in. This seemed to fix it. About 30 minutes later, the same thing happened again.
Now this morning, I tried to turn on my Sky Q box and it wouldn't turn on. I had to unplug it again.
I'm just wondering if anyone else experienced this? My Sky box seemingly has had no previous issues. To me, it seems like a faulty update rather than an error from my end. I also checked all cables and changed the HDMI cable to see if it was that, but the issue persisted.
Re: Sky q and mini box not working
@Debby1960
I've merged your post into this thread that is most likely connected. Don't expect you to read 1000+ posts but suffice to say there has been a massive TV outage overnight. Sky are asking customers to reboot their boxes this morning which is working for the majority.
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
This message was authored by: Raptor606
Re: No signal on sky Q
Expect uproar if this problem persists through and ruins coverage of the Cup Final and Eurovision tomorrow.
Re: Sky Q error?
@Anonymous
I have merged your post too. See my reply (post 1383).
Re: Sky Q error?
Take a look at this thread your post has been merged to.
This message was authored by: GB178
Red light stays on.
Red light on my sky Q  stays on. I turn off the box as advised. It works for around 30 minutes and then appears again.
Locked
Answered - Go to Answer
